Member Build Threads - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 01-08-2013, 08:44 PM
tigerfan79's Avatar
tigerfan79 tigerfan79 is offline
tigerfan79 is starting off with a positive reputation.
  #62
Old 01-16-2013, 10:20 PM
Chris 56 f6's Avatar
Chris 56 f6 Chris 56 f6 is offline
Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.
1956 f6 tandem flat bead (S)
dijokei1275.photobucket.com/albums/y443/Chris56f6/56/b73cc8bc5ef6a8caa22c6f7ab7064c0c.jpg[/IMG]http://www.ford-trucks.com/forums/1217232-1956-f6-tandem-axle-build.html
  #63
Old 01-17-2013, 01:28 AM
1956 f6 tandem axle flat bed build
  #64
Old 01-17-2013, 01:39 AM
Help
Quote:
Originally Posted by COMPLIT1107 View Post
It is becoming harder and harder to track down the great work our members are doing. Build threads keep us up to date on what they are doing or planning to do. As the site gets busier and our time lessened, sometimes these great threads can get "lost", especially if not posted to every few days.
This thread is designed for a listing of members build thread links. No comments, no other stuff, just you putting a link to your build thread.
In your Title put: Year Model and then a Style Code in parenthesis.
Such as: 1951 F-1 Panel (R)
Use the following codes (just to help us sift through the builds if we are looking for something specific. Now you decide how to code it, but the easiest codes would be:
O - Original
S - Original with Safety undates (brakes, etc.)
R - Rodded (Looks like Henry made it, but not after you turn the key)
D - Darkside (Hot Rod) Mostly like Henry, but with your improvements
In order to get your link, open your build thread and at the top click on LinkBack, then LinkBackURL in the top bar. "Copy" the URL, then Create a post in this thread and "paste" in the Link.
Don't get too crazy, like 10 pictures. Maybe a small one, or just the link to keep us in suspense!
If you need to make comments or have questions, post to this thread:
http://www.ford-trucks.com/forums/11...ch-builds.html
Again ... Please - only links to your build threads, no build pictures, no comments. And don't forget the title.......
PS: attaboys to Dano78
John can you please tell my how to build a link to my build site and where to start that build site ? I m doing it wrong
  #65
Old 01-17-2013, 02:52 AM
1956 f6 tandem axle build
  #66
Old 02-02-2013, 05:46 PM
rustyrelic's Avatar
rustyrelic rustyrelic is offline
rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.
1956 ford f600 5.9 cummins 6+4
  #67
Old 03-04-2013, 11:17 PM
Rocketman55's Avatar
Rocketman55 Rocketman55 is offline
Rocketman55 is starting off with a positive reputation.
1955 F250 (R)
  #68
Old 03-13-2013, 10:12 PM
Jim 54 panel's Avatar
Jim 54 panel Jim 54 panel is offline
Jim 54 panel is starting off with a positive reputation.
[B]1954 F-100 panel (DD)[/B]
  #69
Old 03-19-2013, 03:38 PM
mgerdau mgerdau is offline
mgerdau is starting off with a positive reputation.
1955, F350 (S)
I'm starting with the rebuild code of "S" but haven't made up my mind. I do plan on boxing in the frame and I would like to put disk brakes on it but as far as replacing the 239 and the drivetrain I haven't completely decided. Any recommendations would be greatly appreciated. Have had this project for a week and have it down to the frame. I'll start cleaning the frame next week and then clean, inspect, and repair the steering and suspension.
  #70
Old 03-31-2013, 01:20 AM
R. Victor R. Victor is offline
R. Victor is starting off with a positive reputation.
1955 Ford F100
I am a new member and can't seem to find the correct way to Post a New Question, so I will proceed in this format. Please correct me if I am wrong. I have built three antique cars in the past 15 years but never a Truck. I am looking at a 1954 F100 which seems to be in good shape but I have not been able to put in on my lift as yet. The owner has consigned it to a local used car dealer and I must wait for his approval to inspect it while on my lift. Althought it seems that the frame and Body are in good condition from what I can see buy looking under I have discovered what I consider an unusual item that is under both doors. It is a rubbery strip between the door frame and what I believe is called the running board or the place where you step up to get into the cab area. This rubbery strip runs the entire length of the door but is not attached to the door. Both sides of the Truck have this item. I cannot determine how this is suppose to be part of the frame or Chassis/body. I have been unsuccessful in finding a diagram or pictures on the Internet of what this sturcture should look like. I would appreciate any advice on this matter as I would like to buy this truck if the frame, body, suspension and mechanics are in good condition, which they seem to be except for this rubbery item. I have never seen this type of device before on any vehicles that I am familiar with or even trucks. Ron
  #71
Old 03-31-2013, 01:20 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by R. Victor View Post
I am a new member and can't seem to find the correct way to Post a New Question, so I will proceed in this format. I have discovered what I consider an unusual item that his under both doors. It is a rubbery strip between the door frame and what I believe is called the running board or the place where you step up to get into the cab area. This rubbery strip runs the entire length of the door but is not attached to the door. Ron
Welcome to FTE!
To start a new thread, click on the "New Thread" button on the left side on the forum main page.
It would be helpful to answer your question if you would post a picture of the rubber strip to which you refer.
Pictures can be added to your post if they are first somewhere on the Internet. I use Photobucket for this purpose.
Here's one way to put pictures in your post.
Go to Phoobucket.com and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
  #72
Old 04-05-2013, 06:15 PM
1948 F1dude's Avatar
1948 F1dude 1948 F1dude is offline
1948 F1dude has a good reputation on FTE.1948 F1dude has a good reputation on FTE.
1948 F-1
  #73
Old 04-13-2013, 03:11 PM
Ramos1445 Ramos1445 is offline
Ramos1445 is starting off with a positive reputation.
1950 F-1 (S)
  #74
Old 05-07-2013, 02:43 AM
TBHHUNT's Avatar
TBHHUNT TBHHUNT is offline
TBHHUNT is starting off with a positive reputation.
1950 F2 (s)
1950 F2 rebuild, stock with safety improvements.
  #75
Old 05-19-2013, 12:38 AM
CB28424's Avatar
CB28424 CB28424 is offline
CB28424 is starting off with a positive reputation.
56 F100 Build thread "2ND Chance"
56 F100 with a 1970 351 Cleveland Build thread. Just getting the thread started so I will try to update as fast as possible.
http://www.ford-trucks.com/forums/12...56-f100-d.html
Rules of the Road Ford Trucks Official Ford Forum : Ask an Engineer 0 01-06-2016 04:39 PM
We Love to Watch Builds! COMPLIT1107 1948 - 1956 F1, F100 & Larger F-Series Trucks 54 12-29-2015 07:54 PM
How to join the Florida Chapter / New Member Info jimmyb08SD Florida Chapter 0 05-19-2010 07:39 PM
New Members, Please read! fabmandelux Oregon Chapter 0 05-18-2010 02:12 PM
Minions Rigs Pics 79-400-POWER Offroad & 4x4 151 03-29-2008 02:43 PM
Tags
1951, 1956, 49, 52, build, cover, f1, f100, f7, ford, front, ifs, parts, radio, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
