POWER STEERING FLUID LEAK
Old 03-05-2012, 04:23 PM
wulfman's Avatar
wulfman
wulfman is offline
Ok have had power steering fluid leak for about a month have not really had time to fix it so been adding fluid . Well the dam busted and will not hold any fluid now . Got it in garage today and it is one of the hydro boost lines . It is the one on the bottom of the pump , there is a brass 3/8 fitting that goes in and the hard line comes down and goes to another brass fitting that turns a 90 and in to the other fitting it is lose there and leaks bad . My question is can this fitting or line be tighten or does it have to be replaced , and how to get it off .
Old 03-05-2012, 08:07 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
I would try and tighten it at that fitting could just be loose IDK
Im not much help on this one David If mine ever goes out I will be coming to you for advice on it
I was thinking about your issue with the Power stweering today wondered how you made out then I came home and saw your post
What kinda fluid have you been putting back into it I want to do a flush on mine
Old 03-06-2012, 04:28 AM
wulfman's Avatar
wulfman
wulfman is offline
Thanks for the help Benny guess i will give it a try , also time for new radiator hose's lower one has to come off to get to the leaking line .
Old 03-06-2012, 05:48 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
That's gonna be fun David. Mine has had a "weep" there for a LONG time but I've never fussed with it since I don't lose enough fluid to matter. I have no information on tightening the fitting but give it a shot.
Old 03-06-2012, 06:45 AM
sammy77's Avatar
sammy77
sammy77 is offline
I've had the same "weep" for a year now. Getting a new driveway soon so I'll be forced to fix it. lol
Old 03-06-2012, 08:22 AM
69cj's Avatar
69cj
69cj is offline
I use Mercon V synthetic.
Old 03-06-2012, 05:28 PM
BLADE35's Avatar
BLADE35
Did Tightening the fitting work Dave
Old 03-06-2012, 05:44 PM
npccpartsman
HAHA--mine is like the infamous rear main seal leak that has the bell housing drip that never hits the ground.
Old 03-06-2012, 06:30 PM
wulfman's Avatar
wulfman
wulfman is offline
Truck still in garage haven't messed with it yet , lucky i don't need to haul anything now been driving jeep . Boys that weep will get worse trust me i know . When i fix it or get it tighten it will let you all know . I do know that the lower rad hose has got to come off and the fitting is really tight to the pulley so we will see .
Old 03-06-2012, 07:20 PM
npccpartsman
Mine has been weeping for about 150K miles so I'll just let that bitch cry til she squalls--LOL.
Old 03-06-2012, 07:27 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
Ah, I remember scrambling to fix the leaks before the new driveway!
Old 03-07-2012, 09:35 PM
mohle's Avatar
mohle
mohle is offline
If it's like mine, then there is a teflon o-ring on the fitting. They are about 10 cents at Ford. You have to heat them in hot water to make them expand, then quickly install onto the fitting. A simple fix that can be a nightmare. Do not over tighten. Buy a few o-rings in case you wreck one during installation.
Old 03-08-2012, 04:36 AM
wulfman's Avatar
wulfman
wulfman is offline
Thanks for the info mohle haven't taken it off yet but will give it a try.
Old 03-08-2012, 06:37 AM
sammy77's Avatar
sammy77
sammy77 is offline
At least you know where yours is coming from...Mine is power steering and it looks like it's coming from the area below the reservoir but I can't see chit. Gotta pull my bumper off and remove my plow brackets for good and check everything over real well. I also need to deal with my trans lines as they look like they're ready to fall off at the radiator. It's gonna be a costly year for me...
Old 03-08-2012, 06:40 AM
sammy77's Avatar
sammy77
sammy77 is offline
Not to mention what the driveway costs!!
Quick Reply: POWER STEERING FLUID LEAK
