Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-10-2012, 03:13 AM
62RatRod 62RatRod is offline
1962 Ford F-100
62RatRod is starting off with a positive reputation.
Diesel ignition propane injected
I've read most of these threads and nobody I've seen had any ideas or posts about a propane fumigated/diesel ignition engine, so here I am. I have a 82' nissan datsun with a sd22 4 cylinder n/a idi diesel. It gets over 30 mpg but with the diesel prices I am looking for something better. I am fairly knowledgeable about propane injection so I figure I can handle this project. My few concerns are how to limit the diesel injection pump so that it will only serve as the ignition, and where to find a propane hat for the one barrel throttle body.
  #2 (permalink)
Old 05-26-2012, 11:49 PM
nitrogen's Avatar
nitrogen nitrogen is offline
Garage is empty, add now
nitrogen has a very good reputation on FTE.nitrogen has a very good reputation on FTE.nitrogen has a very good reputation on FTE.
you don't need to "limit" the fuel pump. it will do that itself. your foot tells the governor what engine rpm is desired, it increases the power until that rpm is reached. if it is getting enough fuel from another source(propane) it will just inject less diesel because that rpm has already been reached.
__________________
2005 F350 Lariat crew 4x4
traded F350 XLT supercab 4x4 what a stinker
  #3 (permalink)
Old 06-15-2012, 12:23 PM
1962 Ford F-100
This is an idi naturally aspirated motor so it has a butterfly valve that works in conjunction with the injection pump.. So the less vacuum it sees the more diesel it injects,, to a point.. The engine rpm also increases the amount of fuel injected I just want the injection pump to act like a distributor or just the ignition source and have the propane fuel the motor to higher rpms. There is also a rack on the fuel pump that controls how much fuel will be allowed to pass through the pump and it is attached to the throttle linkage,, I guess I will start with unhooking that linkage and plugging the vacuum lines to see if that will work.. I've been looking at impco's website for one barrel propane hats but they only give part numbers. I know they make all different sizes I just don't know how to find out which one will be the same size as my throttle body
Tags
2003, 60, diesel, ford, injection, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
