how is the piece mounted to the axle tube? can i see a pic is it a d60? i got some cage arms with weld on brackets i still need to fully install on my d60, your arms look really good tho.
The upper link is mounted with a bracket that is welded on to the lower.
You will need to preheat the axle before welding to it or it may not get hot enough to penetrate.
I used an oxy-acetylene rig, the welds are still pretty ugly but they have good penetration.
Good penetration is a must in welding and "other" things.
I got the drag link built, I still have to paint it but the angles are spot on.
Also picked a cam and timing set. I went boring with a flat tappet Comp Cam CL32-208 and a double roller timing set. Ordered them on Tuesday and they arrived yesterday!
I think I am going to use some heavy gauge sheet metal to mount them in.
I should be able to shape close enough to mount in place of the factory cluster.
how reliable are them gauges? one part goes out you gotta replace the whole shebang!? i got some autometers and have a falure already. its on a sending unit i think tho.
