1978 - 1996 Big Bronco
78/79 RestoMod
Old 04-14-2012, 03:33 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Picked up the axles today, overall in great shape.
I will need to have the rotors turned and replace the seals on the front.
the rear is missing the E-brake parts on one side, but those should be easy to snag from a JY.
Warn manual lock outs installed already though
  #47
Old 04-14-2012, 05:46 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Thems look pretty good. They would look better with a bit of paint
  #48
Old 04-14-2012, 07:45 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Patience my young padawan! hahaha
  #49
Old 04-17-2012, 10:53 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Started tearing into the front axle today. Got the outers off, I still have to press out the ball joints so I can pull the shafts out.
The unit bearings are pretty easy to pull, I had never dealt with them before and didn't know what to expect.
I had both sides taken down in about 45 minutes.
I also dropped off the rotors to be turned.
This weekend I hope to get the front ready for paint which means getting the spring/radius arm mounts welded on.
I need to get a new dust sheild for the passenger side also.
  #50
Old 04-20-2012, 10:23 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Had a few hours this afternoon, got the axles taken off the trailer and got the front axle mostly stripped today.
Started in on the rear axle. The E-brake on the driver side was completely removed.
The passenger wide was destroyed by a leaking oil seal.
I am thinking it may be cheaper to put a pinion brake on than to replace the stock parts, opinions?
Found these cool little saw horses, they are the perfect height! They were hanging out behind the garage.
Here is a pic of the unit bearing from the front axle, not as bad to replace as I thought.
  #51
Old 04-20-2012, 11:16 PM
GruesomeJeans
Looks good so far, my version of a sawhorse is a milk crate and probably whatever firewood is laying nearby.. I don't even have 2 jack stand of the same size...
  #52
Old 04-21-2012, 05:59 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Got my mounts installed and primed the axle today
A couple of the welds are a little boogery! But they have good penetration, I think I was moving too slow.
  #53
Old 04-22-2012, 02:22 AM
GruesomeJeans
Those welds look a lot better than what mine would look like.. I can't even solder properly >.<
  #54
Old 04-28-2012, 12:55 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
Looks good so far. Having a 78 Bronco and an Excursion (same axles as the Superduty trucks) I can enjoy all of the mods you are doing,
  #55
Old 04-30-2012, 09:22 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Painted the front axle and started the install today
I need to cut down the track bar and rethread it, then start building the radius arms.
This weekend I want to get the rear axle under the frame.
  #56
Old 04-30-2012, 09:29 PM
GruesomeJeans
That looks great so far. I wish i could do that stuff with my truck... It just isn't in my future yet.
  #57
Old 05-04-2012, 08:24 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Got one of the leaf packs assembled today, new bushings (what a pain in the ***), new pads and ORD Zero Rates to recenter the axle in the wheel well.
I did find a good way to get the bushings out though, wedge a cold chisel in the loop and press them out with a 6" clamp.
  #58
Old 05-04-2012, 08:44 PM
GruesomeJeans
Looks pretty good. I wish i would have gotten a picture of my neighbors leaf packs. Their lifting an older 50s/60s ford pickup 18 inches... It's going ti have 47 inch tires IIRC.
  #59
Old 05-04-2012, 09:36 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
That is a damn big tire, I am thinking 38s now that I have 1 tons and can handle them.
I think my lift will be close 8" over stock when finished.
I will most likely end up getting new leafs, 4" lift, with the AAL and the Zero Rates that is what these are.
  #60
Old 05-04-2012, 11:05 PM
GruesomeJeans
Whats AAL? I had planned on doing a shackle flip and some superflex Deavers in the front to go up 4 inches. I might go to 6 though since the lifts are the same price.
Quick Reply: 78/79 RestoMod
