78/79 RestoMod - Page 4 - Ford Truck Enthusiasts Forums
78/79 RestoMod
  #46
Old 04-14-2012, 04:33 PM
Raleigh1's Avatar
Raleigh1 Raleigh1 is offline
Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.
Picked up the axles today, overall in great shape.
I will need to have the rotors turned and replace the seals on the front.
the rear is missing the E-brake parts on one side, but those should be easy to snag from a JY.
Warn manual lock outs installed already though
  #47
Old 04-14-2012, 06:46 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Thems look pretty good. They would look better with a bit of paint
  #48
Old 04-14-2012, 08:45 PM
Raleigh1's Avatar
Patience my young padawan! hahaha
  #49
Old 04-17-2012, 11:53 PM
Raleigh1's Avatar
Started tearing into the front axle today. Got the outers off, I still have to press out the ball joints so I can pull the shafts out.
The unit bearings are pretty easy to pull, I had never dealt with them before and didn't know what to expect.
I had both sides taken down in about 45 minutes.
I also dropped off the rotors to be turned.
This weekend I hope to get the front ready for paint which means getting the spring/radius arm mounts welded on.
I need to get a new dust sheild for the passenger side also.
  #50
Old 04-20-2012, 11:23 PM
Raleigh1's Avatar
Had a few hours this afternoon, got the axles taken off the trailer and got the front axle mostly stripped today.
Started in on the rear axle. The E-brake on the driver side was completely removed.
The passenger wide was destroyed by a leaking oil seal.
I am thinking it may be cheaper to put a pinion brake on than to replace the stock parts, opinions?
Found these cool little saw horses, they are the perfect height! They were hanging out behind the garage.
Here is a pic of the unit bearing from the front axle, not as bad to replace as I thought.
  #51
Old 04-21-2012, 12:16 AM
Looks good so far, my version of a sawhorse is a milk crate and probably whatever firewood is laying nearby.. I don't even have 2 jack stand of the same size...
  #52
Old 04-21-2012, 06:59 PM
Raleigh1's Avatar
Got my mounts installed and primed the axle today
A couple of the welds are a little boogery! But they have good penetration, I think I was moving too slow.
  #53
Old 04-22-2012, 03:22 AM
Those welds look a lot better than what mine would look like.. I can't even solder properly >.<
  #54
Old 04-28-2012, 01:55 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
Looks good so far. Having a 78 Bronco and an Excursion (same axles as the Superduty trucks) I can enjoy all of the mods you are doing,
  #55
Old 04-30-2012, 10:22 PM
Raleigh1's Avatar
Painted the front axle and started the install today
I need to cut down the track bar and rethread it, then start building the radius arms.
This weekend I want to get the rear axle under the frame.
  #56
Old 04-30-2012, 10:29 PM
That looks great so far. I wish i could do that stuff with my truck... It just isn't in my future yet.
  #57
Old 05-04-2012, 09:24 PM
Raleigh1's Avatar
Got one of the leaf packs assembled today, new bushings (what a pain in the ***), new pads and ORD Zero Rates to recenter the axle in the wheel well.
I did find a good way to get the bushings out though, wedge a cold chisel in the loop and press them out with a 6" clamp.
  #58
Old 05-04-2012, 09:44 PM
Looks pretty good. I wish i would have gotten a picture of my neighbors leaf packs. Their lifting an older 50s/60s ford pickup 18 inches... It's going ti have 47 inch tires IIRC.
  #59
Old 05-04-2012, 10:36 PM
Raleigh1's Avatar
That is a damn big tire, I am thinking 38s now that I have 1 tons and can handle them.
I think my lift will be close 8" over stock when finished.
I will most likely end up getting new leafs, 4" lift, with the AAL and the Zero Rates that is what these are.
  #60
Old 05-05-2012, 12:05 AM
Whats AAL? I had planned on doing a shackle flip and some superflex Deavers in the front to go up 4 inches. I might go to 6 though since the lifts are the same price.
What did you do to the X today? Snowseeker Excursion - King of SUVs 44854 Yesterday 09:27 PM
Replacing the rear speakers in a 2010 Regular Cab propellerhead Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 14 06-22-2016 06:34 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 06:38 PM
2012 excursion released! Snowseeker Excursion - King of SUVs 5 10-27-2011 01:48 PM
Help with clunk (lots of pictures) wilsonriverfisher Escape & Escape Hybrid 10 04-24-2009 01:08 AM
Tags
4x4, 78, 79, bronco, f150, ford, mod, rangers, restmod, resto, restomod, restomods, sale, specs, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
