78/79 RestoMod
#33
Ah ok. Damn those radius arms look nice. I will need new ones if i lift my bronco cause it turns out one of my arm bars is bent out ward go figure. It is bowed slightly where the other is straight. Which side they are escapes my mind right now but next time i crawl under there i can get a picture.
#34
A few goodies arrived today
Lower door posts from LMC
2 1.25" heims so I can get the radius arm brackets welded and get the axle to powder coating
These things are huge!
I will be ordering the other 6 heims and the 2" .25 wall DOM for the radius arms next week. Then it is time to get the roller together
#39
#42
#44
Well today was pretty much a waste of time.
Stripped down the front axle and found a crack in the center section where the long side tube goes in.
So now not only did I waste a few hours I need to buy new axles.
I wanted to upgrade anyhow but couldn't justify it when I had 2 good axles already.
I did get the radius arm mounts welded up and ready for the axle.
***EDIT***
Found a set of 99 Stupid Duty axles with calipers and discs for $500 for the pair.
Picking them up next weekend.
Unfortunately this throws my whole time table off.
Probably setting me a month behind since this money was supposed to go to primer not axles.
***EDIT***
#45
