Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 03-09-2012, 10:58 PM
Blade79's Avatar
Blade79 Blade79 is offline
1989 Ford F-250
Blade79 is gaining momentum as a positive member of FTE.Blade79 is gaining momentum as a positive member of FTE.
Steering shake
Hey guys I need some help. My wife has a 2001 Explorer 4 wheel drive. I replaced the brakes all around tonight. New rotors and pads front and back. Other than having to beat the living crap out of the rear rotors to get them off, everything went as normal. Got everything back together and cleaned up and pulled it out of the garage and when I turned the wheel to pull out of the driveway and the steering wheel shakes when I turn it. Happens when turning both ways. One I pulled out and got up to speed it was fine. It didn't happen again until I was at a stop and turned the wheel. One I pulled out it was fine. Could this be anything with the pwr steering? any help would be appericated.
__________________
Rick Kerfoot
89-F250 Project truck
  #2 (permalink)
Old 03-10-2012, 06:32 AM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Is this something you feel in the steering wheel, or the whole truck? Are you sitting still when it hapens, or moving? Does it do it in forwaed and reverse? What happens if you hold down on the brake when it acts up?
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Quote:
Originally Posted by 67nukeford View Post
Charlie, don't make me come there and kill you...
"If more sane people were armed, the crazy people would get off fewer shots."
  #3 (permalink)
Old 03-10-2012, 09:59 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Sounds like the 4WD is still engaged.....
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #4 (permalink)
Old 03-10-2012, 12:45 PM
Blade79's Avatar
1989 Ford F-250
Thanks guy But I figured out that I some how got air in the pwr steering line. I popped the cap and cranked it all the way left, hold, then crank all the way right and hold. returned to center and filled up the pwr steering fluid. smooth as silk now. I guess where the fluid level was low and it was jacked up it was enough of an angle to get an air bubble. And yes It was only being felt in the steering wheel and not when moving only when sitting still. As soon as I would start to move it would smooth out.
__________________
Rick Kerfoot
  #5 (permalink)
Old 03-10-2012, 01:27 PM
Almost Normal
1995 Ford F-150
Glad you got it figured out.
Did you see that we have a multi state GTG in April? here's the link
http://www.ford-trucks.com/forums/11...bs-thread.html
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
