So I just installed my centric hubs that allow you to use 4x4it rotors. Along with some ebc rotors and pads front and rear. Well the "gear" that gives the signal to the wheel sensor is off center so now my abs and brake light are on cause it keeps losing the signal (checked with a solas pro). My queston is, has anybody else had this problem is so how was centttrics customer service. How well did they stand behind their product.
Thought I should add they are still on my truck because my old rotors and wheel bearings were totaly fried.
The gear the sencor reads was off center on mine. Basically as the tire spun it would get closer and further away. Just remove the tire again and look in there and spin the rotor. And use a long screw driver and even it out.
