5.4V8 DREADFUL SPARK PLUG ISSUE SOLVED !! - Page 2 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-17-2014, 06:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Old 04-02-2012, 04:39 PM
Tiki35 Tiki35 is offline
Tiki35 is starting off with a positive reputation.
A few questions for the OP:
What is the torque rating on your impact? It is adjustable?
Did you "burp" the gun at all during the removal or did you just hit them hard until they came out?
Did you need to use in u-joint and extensions for plugs 3, 4, and 8?
Did you do any engine/fuel treatments prior to the removal?
Did you use any penetrating fluid at all? They look dry.
The electrodes/gap look in surprisingly good shape considering the miles.
I have ordered the sp515's also and although they are supposed to be crimped on much better, it is my understanding they are still a two piece plug.
Did the truck run well right away or did the computer need time to adjust?
Old 04-04-2012, 07:08 AM
mig25's Avatar
mig25 mig25 is offline
mig25 is starting off with a positive reputation.
Spark Plugs removal
*My airgun maximum rating is 1000 Lbs of torque, yes adjustable . I went down to 250 Lbs.
*Yes, I did crank it in burts , did not hold down the gun until the plugs came out.
*Yes, I did use an impact U joint as well as 3" and 6" extentions. I tried to keep the extentions as aligned as possible to the gun.
Look at the picture from my initial post . It shows by the gun the black extentions and U joint I used.
*Yes , I ran Techron concentrated fuel additive. But at the time the intention was to ensure my fuel system was clean, I gues It could have helped soften the plugs, after all they did not look as bad at all even after 110.000 miles. ( Make sure you get the concentrated version of the techron ) There are two types. Walmart sells it for about 8 bux or so.
* No, I used nothing at all.
* Agreed , I was surprised the plugs look good. But it was well worth replacing it, I am now relieved that my truck no longer has a plug that could potentially break upon removal.
*Truck ran just fine when I cranked, no need for any adjustment, reset.
Old 04-04-2012, 09:33 AM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Oh, one other item................
ChemSearch “Yield”, is a product that most "Typical Automotive repair mechanics" would not be familiar with, although it is readily available. It is a product specifically designed for use (originally) for the aircraft industry....which uses a considerable amount of aluminum and in older models- magnesium. It is on the "Suggested" user list of both Boeing/Airbus & GE/RollsRoyce (who build the jet engines) for use on difficult srew/bolt removal potentially caused by steel/aluminum contact.
and if you look up the MSDS for what comprises it (available online), you will be surprised, yeah, us old guys of 40 years ago (not 30) dealt with things that many have forgotten......and now the "industry" is now selling as new "Tools & Techniques".
oh, the MC 515's are welded.
Old 05-12-2012, 09:16 AM
FordCamping FordCamping is offline
FordCamping is gaining momentum as a positive member of FTE.
Hi Guys,
I have the 2005 6.8 V10, same issue as the 5.4 and today I am doing a plug and COP change. I have ran 3 tanks of gas worth with Seafoam injector cleaner, I have Kano Kroil creep for the penetrating lube, New MC Cops and the MC SP-515's, the nickel anti-seize and yes I have the the plug extractor tool if I break one. I even have a 3/8 impact if I can stir up enough guts to use it... I have seen the impact video before and thank the OP for creating this post. That was his 2nd video, the first one was before that one when he was developing the process.
The one thing I cannot seem yet to find is the plug torque when putting the new plugs back in.
My 2005 vintage Ford shop manual says 25 ft lb dry torque. That sounds high as it is around the 28 to 30 ft lb that rips the plug apart on removal. And yes I know the install is different than removal.
Yes, I do agree on the anti-sieze on the plug threads but applying lube will change the application torque down some 20 to 25% to be the same pre-load on the threads as dry. Which is then about 18 ft lb lubed.
What application torque on the plugs did you use and was it dry or lubed?
Thanks in advance.
John
Old 05-12-2012, 10:53 AM
mig25's Avatar
Plugs
I am not sure about the V10 , below is the torque specs for the expedition 2006.
Indeed it is 25lbs of torque....
Old 05-12-2012, 12:23 PM
Thanks Mig25,
This does help. My 2005 Ford shop manual page 303-07A-1 copy righted 2004 states the same torques for the 5.4 and the 6.8 as they use both in the Super Duty's. Both for the plugs and the COP's
The guys at Blownoutsparkplug.com state this
FAQ on torque no 51 and 52
They also are using MotorCraft plugs and say they are nickel plated and do them dry at 28 ft lb.
25 ft lb by Ford and 28 ft lb by Blownout plug are close to the same.
There is the 13 ft lb torque out there but the years of the engine and methods of thinking have changed. I'm just trying to confirm if I can that on this 2005 3 valve modular the 25 ft lb dry is the latest thinking on MotorCraft plugs.
Right now I have all the COP's out and broke loose all 10 plugs. I put the table spoon of Kroil down in the plug well to let it soak and I came in for lunch. Man, are they in there tight and I only moved it a 1/8 of a turn.
On this 6.8 V10 plug 8 and 10 are going to be a treat.... I just may do the impact after the soak over lunch as the thoughts of pulling the ratchet on an angle is pretty high on those 2 cylinders. I hope I can even get the impact in there. It is a small 3/8 one but the room is limited.
Thanks for the pic post. It is truly appreciated.
John
Old 05-12-2012, 12:34 PM
Schlominator Schlominator is offline
Schlominator is starting off with a positive reputation.
I torqued my 2005 plugs with anti seize to 17 lbs. was that too loose? That is what I had read to do. Is it 17 with anti seize and 25 without?
Old 05-12-2012, 08:01 PM
Quote:
Traditional fasteners require 20 to 25% less torque to gain the same preload on the thread verses dry.
If 25 ft lb is the desired goal dry, then 25% is 18.75 ft lb. Not all our torque wrenches are calibraterd to traceable standards so there is error in the average torque wrench from mechanic to mechanic.
Your 17 ft lb lubed is for all practical 25% less then 25 ft lb. 1 or 2 ft lb is not going to make or break the bank.
Hope this helps
John
Old 05-12-2012, 08:07 PM
Just reporting back. I did not have such a good day today. The score is 7 to 3 and I'm not winning....
To not hijack this post, see my saga here.
2005 3 valve 6.8 Plug Change - Cracked Insulators Thanks
John
Old 07-05-2012, 12:25 AM
mlskidoo mlskidoo is offline
mlskidoo is starting off with a positive reputation.
Great photos and tips. Thanks
Old 10-14-2012, 04:59 PM
iniguez310 iniguez310 is offline
iniguez310 is starting off with a positive reputation.
Smile
Hey guys yesterday my 2001 Navi started missing badly i knew it was time to do a tune up on it but i guess i put it off for too long. Bad choice. I got the 5.4L 32V V8 in it. Will the impact method you used still work on the 4-valver?? I noticed most of you are talking about the 3-valvers only.
Sorry if this is a stupid question i just graduated tech school im only 19 so yess im a rookie.
Old 10-16-2012, 09:32 AM
mig25's Avatar
This issue affects only the 5.4 3 valve engines.
  #28
Old 10-16-2012, 09:45 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Originally Posted by iniguez310 View Post
Sorry if this is a stupid question i just graduated tech school I'm only 19 so yes I'm a rookie.
At least you were smart enough to ask instead of thinking you knew the answer. I'd say that's a good start to a post-graduation career.
  #29
Old 10-16-2012, 02:52 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Welcome to the FTE.
Try starting a new thread with your question. Your problem is not uncommon and you will get help.
  #30
Old 11-05-2012, 01:03 PM
onelove98 onelove98 is offline
onelove98 is starting off with a positive reputation.
Ok!! so it appears you'd be the guy I need to talk to! So I was told my 2005 Expy EB was "mis-fireing" (probably did NOT spell that right, LOL) and that I needed a tune up. K, not a problem.. until they told me it would be $700!! So! NOW my engine is "skipping" or as they called it mis-fireing (WHICH BTW THEY TOLD ME THAT IT WOULDN'T HARM ANYTHING.. JUST KEEP DRIVING AS USUAL! Problem is its driving me batty!!!!! I cant stand having to let off the gas at 70 mph cause the way the truck starts chugging!!) and once it gets up around 2000 RPMs it almost sounds like it goes out of gear.. the RPMs go up, but it doesn't feel like its going any faster!! So now they said if I can find someone to put the plugs in for me, they should only be $7 -$8 a piece... problem is... I dont know anyone that could do everything you just showed you did!!! soooo.. gonna try and do it myself, lol , or have my brother help me! Any feedback would be great!!! thanks!!
FRONT DIFFERENTIAL PART II mig25 1997-2006 Expedition & Navigator 1 07-24-2013 05:34 PM
DIFFERENTIAL PINION SEAL - FRONT mig25 1997-2006 Expedition & Navigator 1 07-19-2013 11:10 PM
FIXED !!TRANSFER CASE /MOTOR QUESTION /WHAT THE HEC? FIXED !!! mig25 1997-2006 Expedition & Navigator 1 05-11-2012 09:39 AM
2006 EXPY EB -WATER PUMP JOB - LOTS OF PICS mig25 1997-2006 Expedition & Navigator 3 03-16-2012 07:45 AM
EXPY EDDIE BAUER TRANSMISSION FILTER REPLACE. mig25 1997-2006 Expedition & Navigator 7 01-06-2012 10:41 PM
Tags
150, 2007, 2010, 46, 54, 54v8, expedition, f150, ford, hot, issue, issues, plug, plugs, removal, spark, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
