Frame rust - Ford Truck Enthusiasts Forums
Frame rust
Old 03-09-2012, 05:53 PM
serious_lee serious_lee is offline
serious_lee is starting off with a positive reputation.
Frame rust
I was poking around with a chipping hammer to test some rusty spots on my frame and I found this. It's a relatively small area so I was thinking I could wrap the frame rail and patch in some plate steel. Any thoughts?
<p>
<p>
The stabilizer bar mount is also rusted pretty bad. I plan on just replacing this with some c-channel of a similar size unless I can find a good junkyard part.
<p>
<p>
Old 03-09-2012, 06:00 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
That is NOT good. and that spot of the frame is under some pretty serious amount of stress. I dont think I would go about "patching" that. That would constitute a new frame in my mind
Old 03-09-2012, 06:45 PM
882tank's Avatar
882tank 882tank is offline
882tank is starting off with a positive reputation.
Quote:
My thoughts exactly.
dr1 dr1 is offline
dr1 is starting off with a positive reputation.
Dude, your frame still has paint on it! Thats all im saying... If my frame had some paint left on it, I would be ecstatic. Last work I did rust chips were falling down like someone was pouring a box of Frosted Flakes on me. I dont think I even want to go banging on mine, if you can find holes in yours. Do whatever makes you happy, unless some very specific situation is happening here, then do yourself a favor and dont bang on it anymore, lol.
This is coming from the arch nemesis of rust. I've wheeled, grinded, sanded, and por-15'd more then a couple vehicles.
Old 03-09-2012, 07:03 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Man, some of you guys rust issues freak me out! Thank goodness we don't have all that road salt down here in NC ! I panic every winter when they occasionally spray that salt brine on the roads......
Serious_lee, what truck do you have?
Old 03-09-2012, 07:05 PM
Haha, I'm not slamming it with a sledgehammer. I noticed a different sound in this small spot only. I think some clay or mud got up in there and rotted that little section out. There seems to be plenty of frame left above the hole and this section is doubled up for the steering box. A new frame is not a feasible solution for me unfortunately.
Old 03-09-2012, 08:42 PM
donniezyea's Avatar
donniezyea donniezyea is offline
donniezyea is starting off with a positive reputation.
Very scary location to have holes in the frame *yikes* thats a safty issue in my book.
Old 03-09-2012, 09:23 PM
GNR22's Avatar
GNR22 GNR22 is online now
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
If you're not going to put a new frame underneath it (I wouldn't either) I would weld a piece of C channel on the outside and inside of the frame rail and then fishplate it and call it a day.
Old 03-09-2012, 11:40 PM
SAF SAF is offline
SAF is starting off with a positive reputation.
Patch her up...coat with a high quality rust treatment/paint, no problem
Old 03-10-2012, 12:20 AM
05victorylly's Avatar
05victorylly 05victorylly is offline
05victorylly is starting off with a positive reputation.
yeah I would just clean it up really good and patch it from both sides.
Old 03-10-2012, 01:08 AM
minnesotafisherman's Avatar
minnesotafisherman minnesotafisherman is offline
minnesotafisherman is starting off with a positive reputation.
Yeah where the heck are you at?
My truck was an ex-Michigan truck, and now resides in Minnesota, and we get a lot of salt on the roads but the 20 years of abuse hasn't done anything to the frame of my truck other than some light surface rust. I power wash it several times throughout the winter to keep the salt from building up.
Old 03-10-2012, 08:23 AM
O, you are supposed to WASH the underside of these trucks?
Old 03-10-2012, 08:31 AM
I'm in MD (just got the truck last year), but I know the truck was built in Norfolk, then spent time in West Virginia and Virginia. I have found a lot of orange clay in that section of the frame, so I think that was the culprit since it holds so much moisture. I will do my best to save what I have since the truck has lots of life left with the straight 6 and a ZF OD.
Old 03-10-2012, 10:44 AM
If you live in the Rust Belt
Old 03-20-2012, 09:35 PM
Started patching today. My little 110 welder was working ok, but it would be nice to have a 220 hookup where I'm working on the truck. I think it will be ok for my purposes. I felt like an archaeologist trying to pick all the rust scale and clay layers out of the frame channels. The rest of the frame is solid so it must have been the lack of drainage in this portion.
<p>
Is this a forged crank 300? Notmeofficer Ford Inline Six, 200, 250, 4.9L / 300 6 08-25-2014 09:53 AM
AOD to 5 speed manual transmission conversion PICS fordbroncodave 1978 - 1996 Big Bronco 7 08-16-2014 07:44 PM
new here.. just wanted to show off my project ldwzlaw 1994.5 - 1997 7.3L Power Stroke Diesel 32 07-23-2012 08:14 AM
Front Suspension squeak/creak... does yours? CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 6 06-07-2010 05:30 PM
IDM mod w/pics CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 27 04-25-2010 09:10 PM
Tags
2000, ar15com, body, bronco, east, f150, ford, fram, frame, lincoln, louisiana, navigators, north, rust, usa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
