Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-09-2012, 08:54 AM
RedFordWilly RedFordWilly is offline
Garage is empty, add now
RedFordWilly is starting off with a positive reputation.
Exclamation Hot Air
Hey boys and girls – here’s my problem.
2009 ford expedition (shares many parts with f-150) – the dual climate control won’t cool driver side. Set at 60 just to get cool air, renders hot air at any setting above 60. Heater working fine. Research indicates that my problem may be blend door actuator.
What do you think?
How do I fix it?
Please post pictures or diagrams of “fix”.
Thanks!!
  #2 (permalink)
Old 03-09-2012, 04:32 PM
tseekins's Avatar
tseekins tseekins is online now
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Moving to 2007 and newer Expedition forum.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #3 (permalink)
Old 03-09-2012, 05:11 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Most of the time they have to pull the dash apart. 10 hour job. I know this is older Expies, but maybe worth looking at as an option...
I turned on our 2007 Ford Expedition Eddie Bauer yesterday and heard a distinct knocking in the dash. I previously replaced a blend door actuator in the rear of our 03 Expedition so new immediately the problem. I, however, did not know how to reach the actuator in the 07. I searched and searched and never did find a "how to" for my specific vehicle. I did find a tsb and a how to on how to remove the navigation and this is what I did:
1) There are two pieces of forward facing trim around the navigation/stero and the air controls. I removed the bottom piece first using a thin drywall joint knife. I started on the top right corner, then top left, then bottom. The piece came straight out.
2) I removed the top piece of trim in the same manner. Again it pulls straight out.
3) I unplugged the top two electrical inputs. I marked the right from the left, not that you could get them confused, and left the other electronics plugged in. I let the top trim dangle to the right of the center consol.
4) The navigation is held by 4 7mm bolt screws. I removed all four and pulled out the nav unit. I did not unplug the nav unit put placed it gently on the center consol.
5) The actuator was directly behind the Nav unit, slightly to the right. It was held by two 8mm bolts. I could not access the bolts with a ratchet, so I used a standard wrench. A little difficult to acces the back bolt, but not horrible.
6) Removed the actuator by pulling straight up, unplugged from electrical - a little tricky because there is a lock - push red thingy out then push black tab down, purchased a new actuator from NAPA for $45 and reinstalled.
Total time was approximately 40 minutes. The dealership quoted 6 hours and $800 dollars. Local mechanic wanted $450.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Tags
2009, air, bauer, driver, eddie, hot, internet, lariat, powered, radio, side, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
