Loose Gear Selector..not cable - Ford Truck Enthusiasts Forums
Old 03-09-2012, 08:49 AM
95FordF150's Avatar
95FordF150 95FordF150 is offline
95FordF150 is starting off with a positive reputation.
Brother in-law broke the shifter...One of the two two gold-colored torx screws that hold the upper shifter rod to the lower rod not only popped out but the pot metal it screwed into broke off as well. What do I do now? Any advice would greatly be appreciated. Thanks!
3 on the tree conversion to three on the floor.. 79aldean 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-22-2014 03:11 PM
4W drive won't engage. keith.walters 1997 - 2003 F150 1 12-17-2009 01:21 AM
1975 F-150 Steering Column Problems BSCowboy 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-16-2009 01:06 AM
transmission sofakingkrazy32 1961 - 1966 F-100 & Larger F-Series Trucks 1 01-12-2009 01:30 PM
shifter broke 69ford99 1978 - 1996 Big Bronco 6 09-25-2006 02:07 PM
Tags
2002, 96, bronco, cable, dakota, expedition, f150, f250, ford, gear, gear selector, loose, selector, shifter, sloppy, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
