24volt accessory on a 12volt system - Ford Truck Enthusiasts Forums
Old 03-09-2012, 01:14 AM
BLACK 6's Avatar
BLACK 6 BLACK 6 is offline
BLACK 6 is starting off with a positive reputation.
Alright, I have a 24volt air compressor that I want to mount in my 04 F350 Crew Cab. It has a 6.0l turbo diesel so it has two batteries, of course they are wired to produce only 12volts.
Is there a way to use the existing systems batteries without a total conversion to 24v?
I am good mechanically, and fair electronically speaking. May need a little walking through though.
Thanks,
B6
Old 03-09-2012, 07:04 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
You would need to disconnect the parallel battery arrangement and re-configure the batteries in series so you have 24 volts just to run the compressor.
Probably not very practical, but perhaps, someone else has some ideas...
Old 03-09-2012, 10:58 AM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Old 03-09-2012, 04:08 PM
He'll need to check the current requirements of his compressor, particularly the start-up/surge current, to see how much "juice" is needed.
Old 03-09-2012, 04:56 PM
BPofMD's Avatar
Posting Legend
That thing is up to 10 amps! Should be plenty!
Old 03-09-2012, 07:47 PM
Like I said, it all depends on the inrush current when the compressor first starts.
Old 03-10-2012, 01:51 AM
BLACK 6's Avatar
Thanks, I will dig it out and see if the specs are in the box.
B6
Old 03-11-2012, 08:51 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I doubt it will work. If 10 amps is enough, it's not much of a compressor. Depending on what you have, you may be better off getting another type motor for the compressor. Those little plastic compressors that you can get to blow your tires up in a emergency pull 10 amps or better at 12v.
Old 09-20-2012, 02:54 PM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
Hey Black you ever get this worked out? If not I got some ideas for ya.
Old 09-20-2012, 11:14 PM
Muffinman Muffinman is offline
Muffinman is starting off with a positive reputation.
Just get an Inverter 12 volts to 120 volts with around 1500 watts rating. That works out to 1500\120 volts = 12 amps load side.
Old 09-21-2012, 12:34 PM
Franklin2's Avatar
Quote:
Yep, and that works out to 125amps + on the 12v side. That's a big load on the 12v system.
Old 09-21-2012, 04:45 PM
That isn't what the OP is after though, he wants 24V DC.
Old 09-21-2012, 07:05 PM
BPofMD's Avatar
Posting Legend
See post # 3 ......
Old 09-21-2012, 07:14 PM
Quote:
Originally Posted by BPofMD View Post
See post # 3 ......
Sure but 10A is next to NOTHING, and at $95 might as well buy a 24V alternator. The only thing that is good for is to charge a 24V battery that is only used on occasion.
Old 09-21-2012, 10:45 PM
Quote:
Yes it is and it would be the max he could run off a 130 amp alternator. given the car needs around 25 amps to run the car.
One reason the 1500 watts is max for any normal use.
Converting to 24 volts system is insane. You would have to change everything.
1950 ford truck 6 volt or 12 volts beckman 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-14-2016 03:43 PM
The next advance 12 Volt to 24/36/48 volt? dustyroad General Automotive Discussion 3 06-05-2015 12:07 AM
battery on 6 volt system?? 1950fordf2 Electrical Systems/Wiring 5 03-15-2013 12:08 PM
12 volt vs 24 volt Winch Scorpion2 6.7L Power Stroke Diesel 9 12-28-2010 12:35 PM
Create a 12 volt circuit in a 6 volt system? oldblue92 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 07-19-2009 11:36 AM
Tags
12, 12v, 2008, 24, 24volt, 350, accessories, diesel, duty, electrical, f250, ford, super, system, truck, trucks, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
