Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Big Job Number Help
Old 03-08-2012, 11:02 PM
OldBlueOvalDude's Avatar
OldBlueOvalDude
OldBlueOvalDude is offline
Big Job Number Help
Am looking at a 57 T700 Big Job. Can't tell for sure if the first VIN digit is a 1, I, or T, am assuming it is T. Anyway, VIN is T(?)70N7U34982, date 22F, trans U, axle 16, GVW 28000, 172hp @ 3600, DSO 440202. Exactly what Y block did these things have? How hard is it to find brake parts? Thank you in advance!
Old 03-28-2012, 12:18 PM
wmjoe1953's Avatar
wmjoe1953
wmjoe1953 is offline
Yes, it's "t". T70 equals T-700. '57 should be either a 272 HD for 700, and smaller, or could be when they went to the large motors. In that case, it should be either a 302, or 332 Lincoln Y-block. Most brake parts can be had from NAPA.
Old 03-29-2012, 07:17 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
VIN is T70N7U34982, date 22F, trans U, axle 16, GVW 28000, 172 hp @ 3600, DSO 440202. Exactly what Y block did these things have? How hard is it to find brake parts? Thank you in advance!
T70 = T700.
N = 302 Lincoln derived Y block. This is not the same engine as used in a Lincoln.
7 = 1957.
U = Louisville KY Assembly Plant.
34982 = 1957 Numerical Sequence of Assembly, the trucks specific serial number.
22F = Assembled June 22, 1957.
U = With a 302 = Clark model 250-V3 5 Speed Direct.
16 = Eaton model 28MR Rear Axle / 7.79-1 / 28,000 lbs. Rear Axle Capacity.
440202:
44 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from.
0202 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
You may have trouble finding original wheel cylinders. I may be able to locate NOS originals, other brake parts that NAPA will not have.
Get the parts cluck at NAPA to look in their paper parts catalogs, as I doubt any of these parts will be listed on their computer.
Old 04-08-2012, 10:33 PM
OldBlueOvalDude
Thanks guys. As always, Bill, your decode is so detailed. Unfortunately the truck was up for silent auction and my low ball bid was much to low. Too bad, it would have made a real neat work truck. Hope the successful bidder wasn't a scrapper.
Old 04-09-2012, 09:37 PM
alfm's Avatar
alfm
alfm is offline
Hey NumberDummy,I need ppl like you to advise me where to access parts for older Fords.And btw I know a couple ppl retired from the Ford Truck plant in Louisville as thats where I grew up.Did you happen to retire from there or CA?
roy68
18
06-07-2018 08:13 AM
rchalmers3
Large Truck
04-15-2015 08:43 AM
real550A
Large Truck
10-19-2012 08:57 PM
stockcar1974
02-06-2010 10:23 AM
alexbubernak
07-14-2007 10:02 AM
Quick Reply: Big Job Number Help
