Need front frame horns for 52 F-1 - Ford Truck Enthusiasts Forums
Old 03-08-2012, 11:44 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
Someone cut the front frame horns off on my truck and I would like to buy a couple of extensions to where I can hang a bumper on it.
Mine is cut about 6" forward of the rivet on the top of the frame rail to give you an idea of where to cut. I have attached a picture of my cut-off ones.
Anyone got some I can buy?
tractorman@billstractor.com
Old 03-09-2012, 12:36 AM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Hi Bill, Keeping my eyes open for ya.
The picture may be deceiving me but looks like the rail is bent in towards the middle? Also I'm curious what others here might know about the F-2 F3 front frame rails maybe being the same as F-1's for possible donors????
Later
Josh
Old 03-09-2012, 01:00 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I wish you had posted about a month ago, I just scrapped out a '49 panel.
The front part of a F-2 or 3 might be the same, they have the same front bumper. I don't have my trucks handy to compare.
Old 03-09-2012, 07:14 AM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
when i took the front bumper off my parts truck i cut the horns off when i get home next week ill post a pic and if there long enough you can have them
Old 03-09-2012, 07:21 AM
tractorman
Thanks for the quick replys.
I'll send another picture but my horns are not bent just short .
Tractorman Bill
Old 03-20-2012, 10:39 AM
are you still looking for this and are these long enough
Old 03-20-2012, 10:45 AM
tractorman
Mine is cut about 6" forward of the rivet on the top of the frame rail to give you an idea of where to cut. I have attached a picture of my cut-off ones. Refer to the pict. above.
I guess this is about the only reference I can give you since I don't know how much I am missing. Guess I could always extend your horns if they are too short.
Bill
cell 210-219-6130 San Antonio, Tx.
Old 07-06-2012, 04:57 PM
jmadsen's Avatar
Bill
Hi Bill,
Did you find what you needed? I've got an F-1 frame that the back half was damaged and the frame is getting cut up. Let me know if you still need the front frame horns, Or if anyone else may need/want them.
Later
Josh
Old 07-07-2012, 12:03 AM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Once the original poster find his set I'd be interested in a set as well. My dad's 52 has suffered the same fate. Someone has cut his horns off to move the bumper in closer.
Thanks
Bobby
Old 07-07-2012, 01:34 AM
jmadsen's Avatar
Quote:
Thanks
Bobby
Bill, got your pm. just got busy to respond, ill get some good measurements and pictures to post.
Bobby, I may have a couple from an f3 ? in the near future. i think they may be the same up at the front. ill comfirm that shortly as well and let you know.
cheers
Josh
Old 07-07-2012, 01:36 AM
bobbytnm's Avatar
Excellent Josh, thanks
Old 07-07-2012, 08:05 AM
tractorman
frame horns
Bobby,
I'll neasure and send picts. of the cut off set I got and when I get the measurements off of the full frame I can tell which I need. Possibly we can both be fixed up for horns.
TractormanBill
Old 07-07-2012, 11:34 AM
bobbytnm's Avatar
Sounds good, I'll try and get my dad to do the same
I can't remember how far back his has been cut off.
Bobby
Old 07-07-2012, 02:23 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
The F-1 frames are a bit different than the F-2/3s. The book says the Maximum Side Member Cross Section of an F-1 is 5.92" x 2.25" x .15". The F-2/3 is 6.0" x 2.25" x .19". Like said, since the front bumpers are the same, these figures probably only matter on the wall thickness measurement, and maybe not even then. Stu
Old 07-10-2012, 07:11 PM
jmadsen's Avatar
Quote:
Good to know the difference, now I dont need to measure the F-2 frame section. Although before I read the above info they sure look the same. here is a picture of the F-2 front end.
and below is the F-1 rails. 15 and 3/8" from front edge of first rivit to the end of rail.
I wont be cutting the f-1 frame until earliest next week sometime so Bill let me know how much you need, heck you can have the entire front half if you want?
I'll have both the F2 and the F-1 Rails available
the F-2 rails are going to get cut tonight or sometime tommorrow how much rail do you guys need? do you need it to go past the front crossmember?
Bobby, think these F-2 rails will work? let me know how much to cut?
Josh
"F-150 OEM Filter and Fluid Specs smokersteve 2009 - 2014 F150 17 10-17-2016 03:57 PM
check engine with hand break light on (weak) Swantastik Escape & Escape Hybrid 2 11-10-2015 11:44 PM
GOOD MORNING THREAD DRRXR Southwest Region 5 05-17-2010 08:17 PM
This blinker mod really works!! muleguitar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 26 01-04-2010 11:05 PM
Check Out Our 1997-2005 F-Series Hub Assembly Section 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 05-20-2009 01:34 PM
Tags
frame, front, horns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
