05 Spark Plug - Gas Smell questions - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Log In
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
Old 03-08-2012, 10:35 PM
CelticDevilDog's Avatar
CelticDevilDog CelticDevilDog is offline
New Mexico Chapter LDR
CelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputation
My 05 F150 5.4L 3V KR just recently had the spark plugs changed at 60K because we recently bought the truck and wanted to be sure to not run into the "broken spark plug issue". We had this done at a local reputable mechanic and didn't think anything else about it.
Almost a week later there was a gas smell in the cab and I did some research on this and other forums and figured it was the spark plug change. After a few weeks of my husband not believing there was a gas smell and finally me complaining that I wasn't going to drive it anymore until it was fixed he jumped in the cab and smelled the gas.
He took it back to the mechanic and asked him to torque the plugs down again per the results of my research and the mechanic said that they were already torqued to specs. And they couldn't find the source of the gas smell.
Fast forward two weeks and the gas smell is still there, so the hubby took it back to the mechanic and he found a TSB about the injectors causing the smell and told us to take it to Ford. We did and ford said that the plugs weren't torqued properly. This, of course, got my husband upset because the mechanic he trusts told him one thing and the stealership told him something else.
I pose this question to all the knowledgeable people here: How is it possible that spark plugs that are not torqued properly can cause a gas smell in the cab? I realize that this is a common problem but what is actually causing the smell to permeate the cab? Also, is it possible that Ford has a different torque spec than my mechanic would have for plugs?
Sorry for the long post, just trying to vent my frustrations with everyone else that is having this issue.
__________________
Bobbie
2005 F150 King Ranch Build thread - SOLD
2005 Excursion Diesel No build thread yet, but building a list of upgrades for it.
Click here to join the NM chapter.
Old 03-08-2012, 11:02 PM
Quack Addict's Avatar
Quack Addict Quack Addict is offline
Quack Addict is starting off with a positive reputation.
I had the same gas smell after my plug change back in January this year. After searching on here and talking to a few people, I also returned to the mechanic who changed them. We checked them and four were loose. They had been torqued to factory specs when changed. The boots on the coil packs were the dead give-a-way as to which ones were loose.
Since they were re-torqued, I have had no issues. We even suspected that the fuel rail had been bumped and the o-rings were unseated.....but that was not the case.
If the plugs are torqued properly, try checking for a leak from the fuel rail and possibly change the o-rings in the rail.
Good luck!!!!
__________________
Mike Aka QKADCT
'06 SCREW FX4 5.4L....20's from the factory, ARE shell,
Banks Stinger system, 2 1/2" Autospring, Rear AAL coming
Old 03-10-2012, 11:01 PM
Thanks for the reply. Yeah the trip back to the initial mechanic didn't yield any results, but the trip to Ford did. They said the plugs weren't torqued properly and torqued them. That seems to have fixed the issue.
I'm still confused as to why that would cause a fuel smell in the cab.
__________________
Bobbie
Old 08-13-2012, 09:59 AM
When the plugs are not torqued properly excess fuel under pressure blows up from the combustion chamber and soaks the boots on the coil packs causing the smell of fuel.
It was very easy to figure out the loose ones like I said due to two of them being wet and the other two smelling strong of fuel.
__________________
Mike Aka QKADCT
Similar Threads
Cautionary tale, rough idle, knocking, tick, low oil pressure Crissyfl 2004 - 2008 F150 15 11-24-2014 07:35 PM
gas smell = poor fuel economy? gijim2k1 2004 - 2008 F150 4 05-25-2014 11:05 AM
2006 Ford Escape XLT/225,000 miles MaryG1959 Escape & Escape Hybrid 10 09-13-2013 08:44 AM
Does the Lisle65600 really work? 05ford expy Expedition & Navigator 5 11-22-2010 10:51 AM
92 Ford Ranger XLT 2WD V6 3.0L 130k miles ricket Ranger & B-Series 6 11-14-2003 02:34 PM
Tags
2005, 54, cab, change, expedition, f150, ford, fuel, gas, gasoline, gass, odor, plug, smell, spark, tap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
