1978 - 1996 Big Bronco
1993 bronco tailgate window
Old 03-08-2012, 07:49 PM
Dlooman's Avatar
Dlooman
Dlooman is offline
I have a 1993 bronco xlt and the tailgate window doesn't work but the defrost does. I have checked the fuses, both the dash and tailgate switchs, and the interlock switch on the tailgate latch, and they all work. Can any one tell me what could be keeping the window motor from working.
Old 03-08-2012, 08:23 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
The window motor could be burned up or just not working no more.
Old 03-08-2012, 09:05 PM
AzPete's Avatar
AzPete
AzPete is offline
Try direct power to the motor......then go from that result.
Old 03-08-2012, 10:24 PM
Dlooman's Avatar
Dlooman
Dlooman is offline
I removed the old motor and have a new one to go in, the problem is I don't have any power at the plug
Old 03-09-2012, 07:34 AM
AzPete's Avatar
AzPete
AzPete is offline
Use your volt meter and trace the wires back to see where the power fails at. It could be where the wires fold when the tailgate is closed and opened.
Old 03-09-2012, 09:24 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
It could also be the wires coming from the key switch in the tailgate, i am pretty sure mine is shot in my 78, had to keep the bypass the PO did. I just had to replace the shoddy wiring he had for my own more reliable wiring.
Old 03-22-2012, 09:43 PM
Dlooman's Avatar
Dlooman
Dlooman is offline
Azpete I looked at the wires where they go behind the tail light and found a ground wire after cleaning it up the new motor worked perfectly
Old 03-23-2012, 08:36 AM
AzPete's Avatar
AzPete
AzPete is offline
Glad you got it working.
kirby1111
03-16-2016 09:10 AM
fordka
07-01-2014 12:16 PM
TicoTube
19
05-03-2013 03:03 PM
sixgunz
11-29-2003 11:03 AM
ZiVvmO
08-11-2002 02:10 AM
Quick Reply: 1993 bronco tailgate window
