Engine sizes - Ford Truck Enthusiasts Forums
Engine sizes
Old 03-08-2012, 05:22 PM
Glxy66 Glxy66 is offline
Glxy66 is starting off with a positive reputation.
Engine sizes
What V8 engine sizes were available in a 1964 F700/800. The engine has 5 bolts for the valve cover, but it looks a little big for a FE engine. Thanks for the help. By the way, it is gas.
Old 03-10-2012, 12:41 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
With 5 bolts (the SDs have 8 or more if I'm seeing them correctly) it is an FT. The intake manifold should extend under the valve covers. If so, FT for sure. I take it you know the FE motor, here is a pic of the SD motor:
Redirect Notice
330, 361 and 391 were the sizes. The 330 was a small bore (3.8something, I can't recall) with a 3.50 stroke. 361 was same as a 360, 4.05 x 3.50 and the 391 was the same as a 390--4.05 x 3.78. The 361 and 391 were also designated 359 or 389 late in their runs. These were detuned (even more detuned) smog motors.
Why Ford would designate different CID's for the same bore and stroke motors (also done with the 352 FE, a 4 x 3.50 vs. the 351C, W & M, all 4 x 3.50 motors) is anyone's guess. As a famous motorist in LA said once, "Beats me!!!!"
2005 Ford Excursion 4x4 For Sale rlauer Vehicles for Sale 1 07-31-2015 08:38 PM
No injector buzz when key is turned on? reptyls 6.0L Power Stroke Diesel 2 01-25-2015 07:35 PM
Engine size with casting number StockMan 1961 - 1966 F-100 & Larger F-Series Trucks 3 01-08-2013 03:19 PM
Good Deal? '04 X Cummins f150crewcab Excursion - King of SUVs 7 04-20-2012 01:13 PM
66 F100 identifiy my engine size? johncardi 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-13-2009 04:29 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
330, 73, bore, diesel, emgine, engine, engines, ford, gas, motor, motors, size, sizes, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
