Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-08-2012, 04:22 PM
Glxy66 Glxy66 is offline
1956 Ford F-100
My Garage
Glxy66 is starting off with a positive reputation.
Engine sizes
What V8 engine sizes were available in a 1964 F700/800. The engine has 5 bolts for the valve cover, but it looks a little big for a FE engine. Thanks for the help. By the way, it is gas.
  #2 (permalink)
Old 03-09-2012, 11:41 PM
85e150six4mtod 85e150six4mtod is offline
Garage is empty, add now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
With 5 bolts (the SDs have 8 or more if I'm seeing them correctly) it is an FT. The intake manifold should extend under the valve covers. If so, FT for sure. I take it you know the FE motor, here is a pic of the SD motor:
Redirect Notice
330, 361 and 391 were the sizes. The 330 was a small bore (3.8something, I can't recall) with a 3.50 stroke. 361 was same as a 360, 4.05 x 3.50 and the 391 was the same as a 390--4.05 x 3.78. The 361 and 391 were also designated 359 or 389 late in their runs. These were detuned (even more detuned) smog motors.
Why Ford would designate different CID's for the same bore and stroke motors (also done with the 352 FE, a 4 x 3.50 vs. the 351C, W & M, all 4 x 3.50 motors) is anyone's guess. As a famous motorist in LA said once, "Beats me!!!!"
Tags
330, 73, bore, diesel, emgine, engine, engines, ford, gas, motor, motors, size, sizes, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
