Bronco II Ford Bronco II
Loud Ticking Sound after 15 miles at 65 miles per hour
Old 03-07-2012, 11:41 PM
dencrawford's Avatar
dencrawford
dencrawford is offline
I have an 87 Bronco II - 2.9L. It runs fine on local runs, but when i run on the expressway after about 15 miles it starts ticking like a time bomb. If i get off the exit, the ticking goes away within a mile. Only ticks when running on the expressways for extended mileage with speeds above 60. I have replaced the oil pump, thought the valves might not be releasing and got me up to the 15 miles. You started ticking at 5-7 miles before the oil pump. Any suggestions???
Old 03-08-2012, 04:05 AM
critterf1's Avatar
critterf1
critterf1 is offline
Put a mechanical oil pressure gauge on it and see what it does.
Old 03-08-2012, 07:57 AM
dencrawford
I did that before the pump. It runs at 18 when idle and steady at 42 to 44 when on the expressway. No drop in pressure when it starts ticking.
Old 03-11-2012, 09:16 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Cam bearings are shot, common problem on 2.9s.........unable to keep the top end lubed at constant highway RPMs.
Old 03-19-2012, 03:03 PM
Mostlyford's Avatar
Mostlyford
Mostlyford is offline
Quick fix is changing motor oil weight to 10-40. A lighter oil just doesn't do the job. Long term you prob want to rebuild the heads.
gurdeniii
3.8 & 4.2L V6
11-20-2010 05:43 PM
Bob_91SC4x4
05-13-2005 10:05 PM
jdwitte
1983 - 2012 Ranger & B-Series
01-24-2004 08:39 AM
thoff01
1997 - 2003 F150
12-17-2003 01:32 PM
nlee1188
12-23-2002 01:38 PM
Quick Reply: Loud Ticking Sound after 15 miles at 65 miles per hour
