Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 03-07-2012, 10:55 PM
1925mosin 1925mosin is offline
1994 Ford F-150
1925mosin is starting off with a positive reputation.
Ben Outzen
Exclamation Good news and a bit of a problem
Hey all! I'll go with good news first. I finally added my 94 Lightning to the garage and added some pics and info! Check it out If you are interested.
Second is bad news, I may have a problem. I noticed oil breather cap was spraying a bit of oil down on the plug wires, so i figured to check my pcv valve. After a bit of poking around I found the the air line going from the from the oil filler spout was plugged. Some one had shoved a couple of nuts threaded onto a broken bolt and shoved it into a rubber fitting. Then after more poking around I found where the pcv tube goes into the upper intake. I tried tracing it to get to the valve, but wouldn't you know it, the tube had been cut, bent over and wire-tied shut.
I'm wondering, do I need a pcv valve if I have a breather? I'm assuming yes. If that is the case how do i get put a new one in. Isn't the port for it in the back of the lower intake and do I need to remove the upper to get to it?
Any help would be greatly appreciated!
  #2 (permalink)
Old 03-07-2012, 11:04 PM
1994 Ford F-150
Ben Outzen
Click the image to open in full size.
First pic is what was shoved in the rubber tubing in the second pic. third pic is the wire-tied pcv line.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
