yup another mpg thread sorry - Page 2 - Ford Truck Enthusiasts Forums
Old 03-08-2012, 11:51 PM
Galendor's Avatar
Galendor Galendor is offline
Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.
Quote:
Originally Posted by kedwinh View Post
If your talking about a timing lite for the 300 why not use a vacuum gauge? That's all I use anymore and it works great. Apparently my harmonic balancer has slipped, which I have read is a common problem with the 300, and that was my only option. It's a lot easier than the light is I think. Just hook it up, set timing to maximum vacuum then back it off 2-3 points.
Yes, good point kedwinh. A vacuum gauge is probably more useful than a timing light. I guess I just recomended that because I'm more familiar with using a timing light to check timing than using a vacuum gauge. But agreed, vacuum gauge is probably even better in case the timing marks can't be trusted.
The (only) advantage of a timing light approach is this: using a vac gauge requires adjustment of timing, since you have to adjust to know if you are pulling maximum vacuum or not. With a timing light, if you have faith in the timing marks, you can check timing and know without adjusting anything if you are close or not to correct timing advance. I could be wrong, though.
Old 03-09-2012, 10:28 PM
86bullnose 86bullnose is offline
86bullnose is starting off with a positive reputation.
Probably a stupid question but am a ask . How much does warm up affect mpgs? Not shore about how mpgs are influenced but I let ol blue warm up for a long time at least 15-20 minutes . Hit the throttle one time to disengage the choke an ol girl purred like a kitten she ran sooooo smoothly.
Old 03-09-2012, 10:36 PM
Galendor's Avatar
A warmed up engine likely does get better mpg compared to when its cold!
Old 03-09-2012, 11:16 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I've let mine warm up 10 or more minutes in below-zero temperatures.
But, I'm getting 0 MPG while doing that, so I try to take off as soon as it's warm enough to operate decently.
Old 03-10-2012, 01:39 AM
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
We don't often have really cold weather here but, even when it does get below freezing, I never let it idle more than about 1 minute. Just long enough that it idles good on it's own. But then again I have my chock backed almost all the way off.
Old 03-10-2012, 07:58 PM
So today didn't do much but got the lookin around on my truck an I realize my truck doesn't have a kickdown cable. That connects the carb and c6 transmission. Would that have an adverse affect on my mpgs? I always felt my truck shifts layed back and lax and late . I was goin to look into that . Goin to borrow a timing light to check that out. An the Duraspark conversion is soon to come soon as I get come cash .
Old 03-10-2012, 08:26 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
The kickdown cable will only affect WOT downshifts, if your system is in limp mode the timing is locked at whatever it is set at static, probably 10 BTDC.
Old 03-13-2012, 08:38 AM
the past few days my truck has been running rather good. good power great idle still poor mpg. all i really did was continue playing with the air idle mixture screw, replaced the fuel filter and added some fuel treatment. i also have really been letting the truck warm up properly ( i think that was one reason for the irratic idle) so my bad for that. i have really been ***** footing the truck never driving above 35mph. and i calculated my milage and i am still getting 10.31mpg. i have yet to check timing. i have been soo busy these past days. anymore suggestions i will be glad to take. thanks guys.
My economic 390 project 0ldman 1973 - 1979 F-100 & Larger F-Series Trucks 29 07-07-2014 10:32 PM
5star vs superchips, superchip wins? rayofsi Computer Chips & Tuners 12 01-21-2014 10:55 PM
vacuum easttexas Ford Inline Six, 200, 250, 4.9L / 300 12 08-11-2013 01:35 PM
New Bronco needs a lil pep 85BRONCOXLT 1978 - 1996 Big Bronco 8 11-27-2012 11:07 PM
Fuel Mileage Can It Be True? kermmydog 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 01-15-2007 09:32 PM
Tags
bull, fords, mpg, nose
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
