4.6/5.4 Modular Longevity ?
Old 03-07-2012, 08:29 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Question 4.6/5.4 Modular Longevity ?
We're routinely seeing vehicles going 150,000....200,000+ miles these days.
How long can these 4.6/5.4 modular engines realistically go (with average maintainence) before wearing out ?
Old 03-08-2012, 07:59 AM
Katmandu's Avatar
Katmandu
Katmandu is offline
Question
Come on people !!
My research reveals there is an issue with rod bearings in 02 Explorers w/4.6.
Old 03-08-2012, 09:46 AM
jayton4's Avatar
jayton4
jayton4 is offline
Originally Posted by Katmandu
Come on people !!
I do not think that just because myself and a couple of others have made several posts across two different forums about my issues that it means these engines have a longevity problem. There are lots of different problems that cars and trucks have all the time that never get reported to the interwebs.
Also remember, the Explorer uses an aluminum block, where the vast majority of these modular engines are cast iron.
The maintenance crews of major fleets for taxicab companies and government police agencies will tell you over and over again, that the modular engine is one of the best designs they have ever seen.
Old 03-12-2012, 09:06 AM
tomclem's Avatar
tomclem
tomclem is offline
I'll give my 2 cents on the 5.4 3v engine. It's a POS. The design was screwed up compared to the 5.4 2v that was a lot better engine. The spark plugs, fuel injectors, vvt system, etc on the 5.4 3v is just plain sorry. VCT on any truck engine is worthless. No need to adjust the cam position to squeak out a little better mileage or performance at the expense of problems. The cam phasers and solenoids should be called maintenance items b/c after about 75k they gum up or wear out causing the engine to run like crap and costs a ton to fix. I'll never buy another truck engine with VCT or VVT in it. Ford as well as all the other manufacturers are complicating these engines to their ruin. Sorry to have that opinion but true.
Old 03-23-2012, 12:14 PM
hcbph's Avatar
hcbph
hcbph is offline
Longevity
My 97 4.6 has 186K on it now. Only thing under the hood done to it other than normal maintenance has be an alternator.
Old 03-23-2012, 02:14 PM
F250CCowner's Avatar
F250CCowner
F250CCowner is offline
I do think the 2v engine is better then the 3v engine. If it jusy had more threads in the heads for the plugs i think it would have been as close to perfect as you can get. But if torqued properely it isnt an issue 9/10 times. I do not think its best suited for large trucks like the super duty or excursion just because that is a lot of vehicle to pull around.
Old 03-23-2012, 07:56 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
IMHO, the issue with the cam phasers & tensioners is the same from 20 years ago, with different mfgs....the cleanliness of the oil.....extended frequency durations are ok the for engine in general, but the cam phasers & tensioners, well, they just don't like it!
Old 03-23-2012, 10:32 PM
F250CCowner
This is true. Even though I have used synthetic in my truck I still change at about 3-4K miles. I just don't feel comfortable going longer.
Old 03-24-2012, 02:48 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
Guess you'll never be buying a new truck then, since every current Ford Truck engine has VCT/VVT, the Ram 5.7V8 and future 3.6L V6 both have VCT and VVT respectfully, and even the GM V8s have VCT.
The only truck engines left that don't have VCT/VVT are the ancient GM 4.3 V6, and the Ram 3.7 V6/4.7 V8. All of which are getting phased out anyways. I do not know of any other manufacturer besides Ford that had so much trouble with VCT - and that was only limited to that generation of the Modular engine.
Besides that, Modular engines are very durable. There are even a few running close to/over 1,000,000 miles. Most seem to easily go 300,000 miles.
Old 03-26-2012, 06:56 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
I'm running a '00 E250 with the 5.4, 7800# weight as a daily driver/work truck. Bought it out of Dayton, Ohio in '08 with 203K miles, now has 263K miles. Its been trouble-free since day one, seems to have been well maintained over the years by previous owners (I might be the 4th of record) so I have nothing bad to say about these engines.
In fact I'm shopping for a new-to-me E250 or E350 extended body and have dropped my preference for something of a certain mileage or below. Honestly anything with less than 150K miles would be of absolutely no concern. If I can't find a suitable new van I'll replace the 5.4 with a Ford long block, also without hesitation or concern for its longevity.
Old 03-30-2012, 11:53 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Ford E Vans still use the 2V 4.6 and 5.4 engines. I consider them to be trucks. And yes, the 2V mod motors run a long time; my '02 E150 has just about 104k on the 4.6 engine, and it is as tight as any new engine I've ever owned. There are many trucks, cop cars, taxis, and Town Car limos with 300k or 400k miles on mod motors, still running just fine.
George
Old 03-31-2012, 10:51 AM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Figure all the idling on the Taxi, Limo and CVPI's and you can about double those mileages. 500K+ isn't out of line at all.
Old 03-31-2012, 11:00 AM
F250CCowner
There is a district owned Campus Resource Officer's 03' crown vic at my job that has 450000 miles on it and counting. It has been ran hard to as I speak to the campus officer all the time. He says it still as strong as the newer ones in the fleet.
Old 04-01-2012, 09:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
I have a 2000 F150 XLT 4.6. Regular 3000 mile oil changes.
Right now it's got 268,000+ miles on it. Routine maintenance only and two alternators. Has never had the valve covers off. Uses about 1/2 quart of oil between changes.
Old 05-20-2013, 05:23 AM
BFTUFF's Avatar
BFTUFF
BFTUFF is offline
Q: What year did ford stop using the 5.4L 2V in their E Vans. I am looking for a low milage used one with all the updates, I presume Ford incorporated over the years: thickened spark plug boss with more threads, PI: heads, cam, pistons intake manifold, improved plastic manifold that doesn't warp like in 99'-2000, etc.
My 98' is getting tired and will cost too much to fix all the little noises, may as well drop a newer one in and I want that extra 25 HP to.
Quick Reply: 4.6/5.4 Modular Longevity ?
