How many Miles are on your 4.6/5.4 Modular Engine ? - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 03-11-2013, 09:37 PM
woodworker63 woodworker63 is offline
woodworker63 is starting off with a positive reputation.
woodworker63
Quote:
Originally Posted by millionmileford View Post
Well my old girl was doing good till she just hit 415,263 miles. She is a 2001 ford f150 supercrew. I have a miss and loss of pwer under load with the usual lean fuel codes on banks 1 and 2. Have checked all vac lines and fittings resealed the intake,new plugs and cops, anyone have any ideas . It done this suddenly on a trip thru kansas. Ever since i get a cel that flashes with engine shutter at cruise. give it gas its happy.
have a good mechanic check to see if you are running lean at cruising speeds,use a good injection cleaner(chevron or sea foam) on a regular basis.
  #77
Old 03-11-2013, 10:09 PM
millionmileford millionmileford is offline
millionmileford is starting off with a positive reputation.
have done all those going to put some av gas in it and see if octane change helps.
  #78
Old 03-12-2013, 01:26 PM
BassFantasizer's Avatar
BassFantasizer BassFantasizer is offline
Dirty Old Man in training
BassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputation
Keep us posted. I'm going through exactly the same thing with my '97 5.4.
  #79
Old 03-13-2013, 11:25 AM
GFGODDU GFGODDU is offline
GFGODDU is starting off with a positive reputation.
e250 second owner with 325,000 f250 third owner with 300,000
  #80
Old 03-22-2013, 10:43 PM
3point 3point is offline
3point is starting off with a positive reputation.
miles on my F-250
As of today I have 412,000+ miles on my '99 F-250 SuperDuty. I am the original owner. It has the original 5.4L engine. It's a little tired, but still pulls my 20 ft stock trailer. Until this last year I averaged 35K miles. Change the oil every 3000 miles. It is only on the second clutch. It's a great truck.
  #81
Old 03-25-2013, 04:52 PM
Monypit Monypit is offline
Monypit is starting off with a positive reputation.
97 F150 4x4 has 18,000 on built 4.6L motor. I am original owner BTW.
  #82
Old 03-25-2013, 05:00 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Got your moneys' worth outta that one, didn't you!?
  #83
Old 03-25-2013, 05:46 PM
kyfireopal kyfireopal is offline
kyfireopal is starting off with a positive reputation.
I drive a 1997 F-150 XLT that looks much newer and it has 226,000 miles on it. I am the 2nd owner and have owned it since it had 65,000. It runs great. I need to put new brakes on it right now, but other than that, it's fine.
  #84
Old 04-04-2013, 10:00 PM
As of March 31, 200,000 miles on my '97 5.4 F150 4x4.
As of March 31, 100,000 miles on my '00 6.8 Excursion 4x4.
  #85
Old 04-11-2013, 03:21 PM
BurchFord BurchFord is offline
BurchFord is starting off with a positive reputation.
I have a 2007 F250 with 5.4 3V with 183000. Bought it with 131000 and just changed the plugs last weekend. What a treat that was
  #86
Old 04-12-2013, 08:18 AM
JWA's Avatar
JWA JWA is online now
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Found this on FleaBay: Ford : E-Series Van XLT in Ford | eBay Motors
If those claims are correct---and I have no reason to believe they're not---that's some endorsement for our motors huh?
  #87
Old 04-12-2013, 10:49 PM
shapleigh shapleigh is offline
shapleigh is starting off with a positive reputation.
I recently acquired a '98 250 reg cab 5.4 4X4 with 186000 for $1200, did tie rod ends, adjusting tubes, upper control arms with b/j's, lower b/j's, cv-shafts, and all four universals since the grease seemed to have dried out from extended siting and torn boots and such(only about $300 total in parts). The motor and drive train make no unusual noises(other than the missfire from the cracked cop on #1 it still have to change out). But to get to the point, "Have you driven a ford lately?", I hadn't in a decade and I'm glad to be back in one.
Edit:forgot to mention exhaust manifolds(another $250 in parts), but still under $2k for a 4X4 that should last me a few years.
hoping this truck will join the 400k club
This forum
  #88
Old 05-25-2013, 07:52 AM
Bezik778 Bezik778 is offline
Bezik778 is starting off with a positive reputation.
00 e150 4.6 400,500 miles just retired
00 e150 5.4. 140,000 miles just getting started
  #89
Old 06-03-2013, 12:53 AM
tsd98 tsd98 is offline
tsd98 is starting off with a positive reputation.
Just passed 190,000 on '05, 5.4, Supercrew. Running on its 3rd set of plugs and had to change cats last year due to neglecting misfire due to fouled plugs. Changed coolant, thermostat, and belt at 150K as well. Factory ball joints replaced with MOOG as needed. Other than that, alternator failed at about 160,000 and A/C clutch went about the same time. Regular routine maintenance is key to longevity. Use Mobil 1 5W-40 and have dealer flush tranny about every 50K. Engine and tranny never have never been opened up. Still runs great and body and interior is tight considering the miles and usage. Paint still looks good, too. Very satisfied considering I drive this to work, hunt, tow, and fish with this vehicle. Bought a 2013 Lariat Ecoboost 4x4 in December due to positive experiences with 3 prior, durable F-150s and several good Ford work trucks.
  #90
Old 06-03-2013, 02:23 PM
Jameson JC Jameson JC is offline
Jameson JC is gaining momentum as a positive member of FTE.
This is in the other thread but my (now my fathers) 1998 f150 2wd 5.4l has 328k on it and runs awesome with seemingly endless power. Original engine and tranny, never really any major work done other than brakes and plugs once. When it needed fixing it was always brought in immediately, again, no big $$ fixes over many many miles.
This was my main reason for purchasing a 2002 5.4l f350, ford reliability and longevity.
JC
Why is the bed of so many old Fords twisted towards the passenger side? bb65f1004x4 1973 - 1979 F-100 & Larger F-Series Trucks 13 09-03-2015 02:01 AM
How many miles is to many Drewster2016 1999 to 2016 Super Duty 13 08-10-2015 09:06 PM
How many of our brothers are snowbound? Per4mance 6.0L Power Stroke Diesel 19 11-20-2014 10:51 AM
e4od fluid capacity therigwelder Clutch, Transmission, Differential, Axle & Transfer Case 1 11-12-2014 08:40 PM
1997 f350 crew cab 4x4 diesel fuel tanks capacity sand1 1994.5 - 1997 7.3L Power Stroke Diesel 16 08-08-2014 12:32 AM
Tags
46, 54l, buy, cord, engine, expedition, f150, ford, high, lasted, mileage, miles, repairs, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
