79 ford f100 6bt swap
Old 03-07-2012, 08:07 PM
thornton32's Avatar
thornton32
thornton32 is offline
okey i have been thinkin about this project for awhile and have been all ovr lookin at pics and how to do it. But would rather make a post and get all the information at once. what do i all have to do to make the 6bt fit in this truck i understand the suspension and drive train need to be upgraded. but where can i get motor mounts that will mount right up to this frame without making them and what tranny should i run prefer auto that can take a beating that aint 1000 to buy at a salvage yard but a 5 speed is okey. and how much other parts for the drive train will i need
Old 03-07-2012, 08:23 PM
KingBigJoe's Avatar
KingBigJoe
KingBigJoe is offline
This thread might help you some...
Welcome to FTE, thornton32. I'll give a link to a similar build. I hope this helps you.
https://www.ford-trucks.com/forums/1...ins-build.html
I've been keeping track of that build for the past few days.
Enjoy, KBJ
Old 03-07-2012, 08:26 PM
thornton32's Avatar
thornton32
thanx for the link
Old 03-07-2012, 08:31 PM
KingBigJoe's Avatar
KingBigJoe
Originally Posted by thornton32
thanx for the link
No problem. I'm glad to help you out. If you start this build please start a thread here documenting all the things you did to the truck (hopefully with pictures) during the build.
Old 03-07-2012, 09:12 PM
thornton32's Avatar
thornton32
will do still looking for a cummins and tranny so i can start
Old 03-07-2012, 09:14 PM
KingBigJoe's Avatar
KingBigJoe
Cool. I (& many other FTE'ers) will be looking forward to that thread when the time comes.
Old 03-12-2012, 11:47 AM
speedyweasel's Avatar
speedyweasel
speedyweasel is offline
Count me in for the buildup. There's a pair of good writeups by two different guys on FSB - and I think both double posted the threads here on FTE. Look up the build threads by gos and AmericanThunder over on FSB and here.
Both did very clean, thorough writeups on how they pulled it off. gos' is on a newer chassis, though. AmericanThunder did his on a dentside, so that might be more appropriate for your experience.
Old 06-23-2012, 06:18 PM
thornton32's Avatar
thornton32
Desided to go with the 7.3 idi got a good deal on a 93 with 105000 on it but my 79 is having problems it has a 360 in it with a c6 auto tranny but I thought the solinoid was junk so i replaced it then it ran now i was goin to put aftermarket radio in to find out my radio harness is cut up an dnt kno wat wires r wat but the main problem is when I go to start it nothing not even a noise from starter or solinoid an nothing works dash lights or running light or wipers fuses r all good Idk wat to do an if u can help can you upload a pic of the radio wires an Wats a as battery wire thanx
Old 06-25-2012, 10:10 PM
zolson's Avatar
zolson
zolson is offline
cummins 12valve backed up with an NV4500 5 speed would be a good start. check out craigslist oops didnt read that you had an IDI but a ZF5 would back up that 7.3 nicely
Old 06-25-2012, 11:18 PM
thornton32's Avatar
thornton32
Cummins was to much to do swap an I already have a 06 cummins so i was turning to throwing a ford in a ford
Old 06-25-2012, 11:53 PM
zolson's Avatar
zolson
zolson is offline
nice. it is always nice to keep it in the family
Old 06-26-2012, 02:55 AM
jcarrick's Avatar
jcarrick
jcarrick is offline
Im interested in how this swap goes and how much it will cost you. Im thinking of doing the same thing in an old high boy. Those IDI's are great.
Old 06-26-2012, 07:32 AM
thornton32's Avatar
thornton32
I bought a whole tuning truck so not much which is nice
Old 06-26-2012, 11:01 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
you mean $ wise or fabrication wise? I'm guessing the IDI is probably a similar amount of work.
Old 06-26-2012, 11:57 AM
thornton32's Avatar
thornton32
I ment to say running its goin to only cost me a new tank an having the drive shafts sized
k_brenner
03-18-2013 05:33 PM
ahapp88
09-20-2012 11:22 AM
DaytonaTunnel
08-14-2010 07:37 AM
masterhummer
12-15-2003 08:50 AM
ford4life69
Texas Chapter
10-31-2002 09:16 PM
Quick Reply: 79 ford f100 6bt swap
