Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-07-2012, 07:52 PM
PathAss PathAss is offline
Garage is empty, add now
PathAss is starting off with a positive reputation.
Cool 92 inline 6 wont start for anything
I parked it one night and the next morning I went to start it and it will crank but not start. I sprayed ether in the air intake and it started right up but would only stay running if I had the pedal floored. I checked the spark and it was good. Both tanks are coming on. I hooked fuel pressure gauge up and its reading 55 with the key turned. I changed the fuel pressure regulator, fuel filter, air flow sensor, and injectors. And still it wont start. I checked the timing and its good. I put fuel treatment in the gas and still nothing. Checked all my relays and fuses and theyre good. Then I realized my file pumps weren't shutting off with the key turned. So now can someone please help with what is going on. I'm going crazy
  #2 (permalink)
Old 03-08-2012, 12:17 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250 Rusty_Old_F250 is offline
Rusty_Old_F250 is gaining momentum as a positive member of FTE.
This is just a guess, but have you checked the throttle position sensor?
Sam
__________________
1973 F250, 390 4spd 7500 lbs GVWR, known as "Grumpy" a name well earned
1992 Dodge D250, 12v Cummins, "Babe the Big Blue Ox"
next project: 1966 Mustang 200 3spd- sat for 15 years!
"Man does not control his own fate. The women in his life do that for him." - Groucho Marx
  #3 (permalink)
Old 03-08-2012, 01:16 AM
I replaced that a while ago but that wouldn't explain why the fuel pump keeps priming.
  #4 (permalink)
Old 03-08-2012, 11:35 AM
Truckin Bob Truckin Bob is offline
Truckin Bob is gaining momentum as a positive member of FTE.
Quote:
There was a post similar to what you've got going on a couple of months ago.
Click here : http://www.ford-trucks.com/forums/11...d-no-code.html
Don't get bored and skim over it....there's some really good info in there for you.
Be sure to read the "how to repair your ecu/computer" link.
It may save you some dough.
Good Luck !!!
Bob
__________________
94' F-150 300 I6 EFI 4X4
  #5 (permalink)
Old 03-08-2012, 12:36 PM
Doesn't have anything to do whither what's going on.
  #6 (permalink)
Old 03-08-2012, 06:56 PM
Yea I'm wondering if it may be the ecm. Do they just quit like that? Now that I remember it was idling crappy. Kinda sounding like it wanted to die but with alitle press on the pedal back to normal. Never would die.
  #7 (permalink)
Old 03-08-2012, 07:36 PM
Well then, let me "spoon feed you" what you need to check.
CLICK ON THIS LINK:A9x ECM's (and same years ECM's) Failures Due to Age
AND PAY ATTENTION TO THIS:"What you see is the typical electrolytic capacitors leak, causing intermittent shorts/opens to the neighboring circuits/components and symptoms as the ones explained. Worst case scenarios with this type of failure, is a permanent no start and permanent damage to the PWB"
Unless you're independently wealthy and can throw unlimited cash at your truck, I'd suggest you check your 20+ year old ecm that has probably seen better days.
Good enough ?????
Bob
__________________
  #8 (permalink)
Old 03-08-2012, 07:49 PM
Yea actually and i appreciate it. What is a pwb?
Tags
1966, 200, inline, mustang, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
