Crew cab on reg cab frame - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 01-04-2014, 12:25 PM
Djstright Djstright is offline
Djstright is starting off with a positive reputation.
Does anybody have the factory measurements for a crewcab short box I'm trying to compare frames with a supercab long box
  #32
Old 01-04-2014, 04:22 PM
crewcab79 crewcab79 is offline
crewcab79 is starting off with a positive reputation.
Crew cab short bed wheelbase is 150" and super cab long bed wheel base is 155" as far as I know. I can go measure the total frame length on both if you want.
  #33
Old 01-04-2014, 04:57 PM
Yeah that would be great if you didn't mind. I'm trying to find out what would be the best way to go with my new crew cab right now it's a long box 2wd that someone has cut the frame on and I could weld it back up easy enough but I think I want to do a short box
  #34
Old 01-05-2014, 05:31 PM
Crew cab short bed 228 5/8. Super cab long bed 233 5/8
  #35
Old 11-10-2014, 02:05 PM
Does anybody have any measurements for the box I have all the parts but I want to start there and would prefer measurements that someone already has
  #36
Old 11-11-2014, 10:00 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Are you just looking for the box dimensions? If so, here's the body stuff from fordification:
http://www.fordification.net/tech/im...tyleside76.jpg
And the main body page:
1976 Ford Body Builder's Layout Book - FORDification.net
  #37
Old 02-18-2015, 11:54 AM
huberkj huberkj is offline
huberkj is starting off with a positive reputation.
Bad picture of it but in the works of cutting cap down to fit. This is a regular cab long box frame cutting was pretty easy. Hard part was making the 5Litre fuelly work good
All 3 of my toys
Cab a bed swap bielaf 1999 - 2003 7.3L Power Stroke Diesel 5 01-03-2017 10:39 AM
Crew cab on Supercab frame? J ballan 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-27-2016 02:38 AM
79 crew cab Firemedic79 1973 - 1979 F-100 & Larger F-Series Trucks 14 10-28-2016 03:44 PM
Finally own a crew grinnergetter 1967 - 1972 F-100 & Larger F-Series Trucks 302 07-16-2016 01:37 AM
Crew Cab Cutout for Power Mirrors? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 10 11-06-2013 08:21 PM
Tags
1978, 1979, 78, box, cab, converting, crew, dodge, ford, frame, reg, regular, short, sweet, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
