1988 f250 4x4 IFS front axle - Ford Truck Enthusiasts Forums
Old 03-07-2012, 05:39 PM
kirks71 kirks71 is offline
kirks71 is starting off with a positive reputation.
Hello, I have a 1988 Ford F250 4x4 Diesel 5 speed that I have been playing with as a project. It has the Dana 44 IFS front axle in it. I was wanting to change this to a solid axle. Does anyone know which solid front axles will fit into this truck as a bolt in, year wise or if any years are a bolt in (proper width, etc.) Thanks for your help, its greatly appreciated. Kirk
Old 03-07-2012, 05:51 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
The Bronco guys have this down to a science: Solid Axle Swaps - FSB Forums
Old 03-07-2012, 06:18 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
It's more likely that you have a D50 front end, but none the less, I've done the swap.
It's actually pretty straight forward. I used a Dana 44HD from a late 70's hi boy as a front axle. If you use a Dana 60 from a 4x4 F350 around the same year (it will be a king pin front end, which is tougher) it should pretty much be a bolt in deal. Anyway though, you need to get a straight axle, a drag link for it, some kind of steering set up (when I did mine we made tie rods for it that are thicker for off roading). When I put in my axle I also lifted the truck with F350 springs from a 90.
The downside of using the older axle in my truck, was that the spring perches were to close together on the 44HD and had to be moved over, but that was only about a 7 minute job.
All in all, a SAS will probably take you a couple days. When I did mine, it took me and two other guys (both of which had done the swap with hi boy axles before) about 2 and a half days to get her back on her wheels. Taking the old axle out took about 3 hours, maybe less. Taking the other axle and measuring it out and centering it, moving the perches over and such, took probably 4 or 5 hours. Bolting the axle itself in to the new U bolts and putting the bigger springs in took about 3 hours or so. Putting in the steering and drag link probably took 4 or 5 hours (that includes making the tie rods though). And it was good to go from there. I think it was definitely worth the time and effort to do. It rides way better than the D50 did
Old 03-07-2012, 06:24 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Dana 60 from a 85 1/2 to 97 F-350 is a direct bolt in.
if you can, look for an axle out of a 85 1/2 to 91 F-350, this will be a kingpin axle, and then when you go for front end or brake parts all you will have to do is ask for parts for a 88 F-350 4X4
you will want to get all the parts associated with the front axle. track bar and mounting bracket, steering components, and springs if you can get them.
you can use the 250 springs, but it will ride better with the 350 springs.
Old 03-08-2012, 01:41 PM
Thanks so much guys for your time and knowledge. sounds like the right way to go.
Old 03-08-2012, 01:50 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Quote:
Not true. only way to get a dana 50 in this year truck from the factory was to have an extended cab. all reg cab f250s came with a ttb dana 44hd, even the diesels.
Old 03-08-2012, 03:03 PM
GNR22's Avatar
What years is that true for? My 89 had a D50.
Old 03-08-2012, 07:07 PM
i ain't rite
Quote:
nope. the 2 88 F250 regular cab diesels i had had Dana 50's in them.
Old 03-08-2012, 07:17 PM
rla2005's Avatar
There was a long drawn out thread on here before on what triggered whether or not a F250 got a D44 or D50. I do not remember the details, but long story short it is best to just look at the hubs to figure out what you have. Ford seems to have no real rhyme or reason in the methodology from year to year or gas versus diesel and other factors.
Old 03-08-2012, 07:56 PM
GNR22's Avatar
Thank you gentlemen. I knew I wasn't crazy because I have seen both combinations. I figured that the Diesel combo automatically had a D50 though. Thanks for clearing it up.
Old 03-08-2012, 07:59 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Not true at all. Yes, you automatically got the Dana 50 with the extended cab but you also got it with the snowfighter package even with a regular cab.
Old 03-08-2012, 09:41 PM
Blue Rebel's Avatar
Quote:
What I should have said was I have never seen, in person or on the internet, an 87-91 reg cab truck with a dana 50 axle from ford. Every reg cab ive run across in junk yards, at truck pulls, and randomly running around has had the d44hd. I know i havnt seen it all, just waiting for proof im wrong
GNR, do you have any pics of your truck from before you swapped the axle?
Old 03-09-2012, 12:07 AM
GNR22's Avatar
I'll do a little bit of digging and see if I can find one.
Old 03-09-2012, 12:08 AM
Blue Rebel's Avatar
Kewl, thanks. Not doubting, just never seen one in person, or even a pic of one.
Old 03-09-2012, 12:22 AM
GNR22's Avatar
I found 2 pictures of it before the swap, and neither one are from the front of it. It's actually the 2 pictures that were on craigslist when I bought it.
Which is a lot different from this
1988 f150 reverse problem kirk12315 1987 - 1996 F150 & Larger F-Series Trucks 1 03-02-2016 03:46 PM
water leak Jerry Kirk 1997 - 2003 F150 1 10-22-2014 12:01 AM
1999 f250 triton v10 won't lock at the hub in 4x4 Kirk.ri 1999 to 2016 Super Duty 10 11-28-2013 08:14 PM
88 F350. How does TTB or IFS Axle handle being lifted? RedDevil460 1987 - 1996 F150 & Larger F-Series Trucks 38 02-24-2013 10:32 PM
96 F150 solid axle swap Rusty36 1987 - 1996 F150 & Larger F-Series Trucks 29 05-04-2012 09:14 AM
Tags
1988, 1989, 250, 4x4, 87, axle, axles, end, f150, f250, ford, front, removal, specs, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
