fuel gauge sending unit question - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-07-2012, 02:40 PM
slaviers slaviers is offline
slaviers is starting off with a positive reputation.
I have a 2006 F250 extended cab with 5.4l engine and 38 gallon fuel tank and 160,000 miles. When cold, the gauge reads fine, but after warm up it goes to E and shows low fuel. I just installed a new Ford OEM pump/sending unit (yes $500) combination and problem is still there. when tank was down I checked wiring harness and plug next to tank and found no problems. Unit is still the same. New and old sending units seem fine ( I was not going to go to trouble of dropping tank and not changing the unit out). Both new and old sending units read 15 ohms on empty and 160 ohms on full and seem to change readings evenly through out range. I then found a couple of wires "naked" and rubbing the top front shock bolt in the engine compartment.. I traced these wires into the main harness that was coming from the rear of the truck that also feeds the pump/sending unit in the tank. Insuloated these wires thinking that was the problem.. Sorry, no such luck. My question is this? Does the sending unit hook to the gauge directly, or does it report to the PCM and then PCM reports the reading to the gauge. IF this is the case, then the gauge or the PCM could be at fault. I thought the naked wires I found could be bringing the resistance of the sending unit down towards zero and making the tank look empty.
ps. I also had a brake controller fault ( trailer wires are in the same harness) at times. However, I found water in the rear connection plug and unplugged it. The fault disappeared and did not reappear even after I dried it out and put dielectric grease in the plug.
Any help would be appreciated.
56 gas gauge, help an idiot . DR Smith 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 06-13-2014 04:36 PM
Sending Unit Operation?? bruno2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-18-2014 06:34 PM
1991 E350 RV fuel gauge issue... lhutter1 1968-2013 Full Size Vans 3 01-15-2013 07:06 PM
F250/460 Rear Tank Fuel Pump Parts Help Needed Phil527 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-05-2012 12:20 AM
Fuel Gauge Mystery Solved WMRiceman 1999 - 2003 7.3L Power Stroke Diesel 5 08-18-2007 10:50 PM
Tags
2006, 2009, 54, diesel, duty, f250, ford, fuel, gauge, level, removal, sender, sending, specifications, specs, super, truck, unit, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
