1976 f100 2wd lift - Page 2 - Ford Truck Enthusiasts Forums
1976 f100 2wd lift
Old 03-11-2012, 12:52 AM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
It's not hours of geometry - you simply lower the beam pivot point the same amount as the height of the lift in the coil. If you don't build extended or longer radius arms you should lower the radius arm mounts too.
Now the reason many people don't do this is there is a LOT of leverage on the beam pivots 7 extending them 4" is like using a longer handle or lever on a wrench or ratchet = MORE torque applied to the end. You have to gusset the **** out of them & make them REALLY strong to get them to live 5 minutes...
Old 03-12-2012, 06:18 PM
Fexx22 Fexx22 is offline
Fexx22 is starting off with a positive reputation.
Im curious how did you bend the i Beams?....Thanks
Old 03-14-2012, 11:45 PM
76Hauler's Avatar
76Hauler 76Hauler is offline
76Hauler is gaining momentum as a positive member of FTE.76Hauler is gaining momentum as a positive member of FTE.
i do believe that AutoFab uses a 100 ton press. i have heard of guys heating and using a huge cheeter pipe to bend, and i've seen guys "pie cut" in multiple places, bend to desired deegree, than weld up cuts and plate.
First we inspect the king pin end then straighten the I beam. We have a 100 ton press in our shop to accomplish this ! 90 percent of the time the beams are tweaked from hitting a curb or ditch and even previous bending at alignment shops. Their common practice is to bow the beam to correct minor camber changes. -Autofab
wheel travel early ford
2WD twin I-beam lift mark460 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 06-02-2016 03:06 PM
2000 f350 7.3 lift suggestions Melendez7.3 1999 - 2003 7.3L Power Stroke Diesel 7 01-05-2015 07:13 PM
Body lift? Pros and Cons Mustangking1 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-08-2013 03:02 PM
[RESOLVED] New leaf springs bed still sags minnesotafisherman 1987 - 1996 F150 & Larger F-Series Trucks 47 10-04-2012 01:52 PM
Need more lift on my F350........ F3fitty Offroad & 4x4 25 11-27-2010 09:41 PM
Tags
1968, 1970s, 1976, 2wd, beams, coil, f100, f250, ford, kits, lift, lifted, ranger, size, spring, wd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
