Fuel selector valve 3 or 6 port? - Ford Truck Enthusiasts Forums
Old 03-07-2012, 05:14 AM
MS82F150XLT's Avatar
MS82F150XLT MS82F150XLT is offline
MS82F150XLT is starting off with a positive reputation.
Hi All,
I'm planning to bring my 82 f150 xlt w/big six back to the world of two tanks where she belongs. When searching for a new selector valve I have two options, 3 or 6 ports. Which one is correct? Thanks!!!!
Old 03-07-2012, 12:51 PM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.
Old 03-07-2012, 03:37 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
If you don't have return lines (part of fuel injection) then the 3-port is indicated.
Old 03-07-2012, 05:17 PM
cliffordingles's Avatar
cliffordingles cliffordingles is offline
cliffordingles is starting off with a positive reputation.
You probobly have a 3 port. my 86' F-250HD has the 6 port.
Old 03-07-2012, 06:33 PM
Thanks Jim, Clifford and Ctubutis!!! I'm gonna look online tonight and either order on the web or get the parts at the zone or o'rieley. Gotta buy sending unit, valve and tank.
Old 03-07-2012, 07:05 PM
Have you looked at yours? It's located inside the frame rail on drivers side pretty much at the front of the bed. It's very easy to find and you should really look at yours before you get a new one...
Old 03-07-2012, 07:59 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The 460's, diesels, and some of the fuel injected trucks take the 6 port because like was said, they have fuel return lines to both tanks. All the other engines with regular engine mounted pumps and carbs have the 3 port.
Old 03-07-2012, 08:03 PM
Quote:
Mine has a 351W with the 6 port... I was told the 6 port came on the HD's
Old 03-07-2012, 08:32 PM
ctubutis's Avatar
HD, LD isn't the correct criteria to use; what matters is the fuel system - return lines or not.
"HD's" before EFI won't have 6-port valves as there are no return lines, they came about with EFI.
Old 03-07-2012, 08:33 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
1982 = 3 port.
Quote:
Unless it has hot fuel handling. Carbed 460's notoriously had vapor lock. The fuel on these were constantly circulated to prevent this, to cool the fuel off. Hot Fuel Handling = 1984+
Old 03-07-2012, 08:41 PM
I'm not saying your wrong but my truck is factory and i'm the second owner. Mine has the 6 port along with the return fuel lines and a carb...
When i went to the parts store to replace it like a year ago i was given the 3 port then found out mine is a 6 port. I took it back and the guy said mine must be a HD. It was an option in his computer.
Old 03-07-2012, 08:43 PM
ctubutis's Avatar
Quote:
Yeah, it just now occurred to me when I saw the reply from you - you're telling me how I'm wrong or how I forgot something, *then* I remembered about the hot fuel handling stuff.
I was honestly wondering to myself if feedback carbs have them but I seem to remember not.... local guy here brought his truck to my house about 8 months ago, had a 6-banger with a feedback carb, we disconnected the fuel inlet line and I don't at all remember there being any return lines so I was kinda out on a limb there and not at all thinking of 460s and all their woes.
Old 03-07-2012, 09:36 PM
I looked and my truck doesn't have return lines. I have the mech pump on the block. I did look briefly at the valve when I had the truck on the rack but hadn't paid attention then as everything was disconnected from it. After hearing everyone's advice it sure seems there is no chance I need a six port. The pump only has one line in and one out. The carb has one in and none out.
Old 03-07-2012, 11:00 PM
Quote:
You need the 3 port valve.
The Hot Fuel Handling and EFI 6 port valves started in 1984.
Old 03-07-2012, 11:15 PM
ctubutis's Avatar
Listen to 81-F-150-Explorer, *he* is an expert, I'm just a backyard apprentice.
6 port selector valve to 3 port selector valve bullnose1985 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-22-2015 10:41 PM
1986 fuel tank selector valve 6 port OConnorRacing Fuel Injection, Carburetion & Fuel System 1 06-27-2014 04:46 PM
86 fuel tank selector valve ????? OConnorRacing 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 06-19-2014 06:36 PM
1988 Ford F150 XLT Lariat - Fuel Selector Valve Gil Norman 1987 - 1996 F150 & Larger F-Series Trucks 2 05-22-2014 09:39 AM
By Passing Fuel Swicth 05chop 1987 - 1996 F150 & Larger F-Series Trucks 6 04-24-2008 07:26 PM
Tags
1994, 50, 86, f150, f250, ford, fsv1, fuel, port, replacement, selector, series, slector, tank, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
