5 speed on a 390 FE in my 73 F250
Old 03-06-2012, 07:03 PM
Creamsiclejohnson's Avatar
Creamsiclejohnson
Creamsiclejohnson is offline
i want to put a 5 speed in my truck so bad but i have done all the research i can and have turned up with nothing. im hoping someone knows what tranny i should use and what else i would need, adapter plates Clutch lickage drive saft and yoke stuff all that please comment and give me ideas as of what i need to do and what Over drive transmission i would need. i need help
Old 03-06-2012, 07:37 PM
impalaslayer's Avatar
impalaslayer
impalaslayer is offline
to my knowledge there is no 5 speed that will bolt to the FEs, but i could be wrong
Old 03-06-2012, 08:08 PM
7636074460's Avatar
7636074460
7636074460 is offline
you and me both buddie!
i have found that quicktime bellhousings just came out with one to adapt to an AOD, not sure which boltpattern( id assume smallblock) if a guy could use this adapter to use a standard trans from the same boltpattern?
I think the only way to do it is to make/use a bellhousing adapter, or what i have been trying to find is a t5 or t6 or any trans that has a seperable gearbox/bellhousing, and adapt(if necessary) to my 360 bellhousing (i have a t18)
so at that note you could find a bell off a 360/390 with a 4spd std trans and adapt from there
Old 03-06-2012, 09:59 PM
Ohiocrewcab's Avatar
Ohiocrewcab
Ohiocrewcab is offline
You are gonna want the ZF-5 for your truck. You have to make an adapter plate to mount it on there. If you have a machine shop available they can make it for you. I'm in the process of getting all the hole locations for my truck so I can mount a 460 based ZF in my truck. I just haven't found the time to put the M-block bell housing up on the mill yet. Mine will be made from scratch and won't happen super fast since I can only get it up on the mill on my day off which I still have yet to see one of thoes. Ford made a ZF for the Windsor blocks and the AOD was a Winsor block trans so that should work for a faster solution. If I have confused you let me know. I apologize if I have.
Old 03-06-2012, 10:27 PM
bigperm2's Avatar
bigperm2
bigperm2 is offline
The way I see it, you have 2 options.
1.) use a nearly $1000 adapter to mate a windsor or 460 bellhousing ZF transmission. There are a few companies out there that carry this adaptor. It is a plate that bolts to the block + a flywheel adapter/spacer.
2.) I believe advanced adaptors sells a simpler adapter for to use a dodge NV4500. The NV4500 does not have an integral bellhousing, and you would use your stock FE bell.
Good luck! If you do it, it would be a sweet powertrain!!
Old 03-06-2012, 10:55 PM
JustBlaze's Avatar
JustBlaze
JustBlaze is offline
You could use a clark 5 speed and bell housing from behind a ft in a f600 +/-
Might be a little rugged for the application though, I think they came with 5th as a direct and some with 5th as an overdrive. I drive a f600 with one every day almost and it's not too bad.
Old 03-07-2012, 08:07 AM
Creamsiclejohnson
i thought someone had posted one where they where they put lik a dodge transmission called lik a nv4500 behind a FE block anyone know anything and i want a manual to stay in it.
Old 03-07-2012, 08:49 AM
Ohiocrewcab
The NV4500 is a 5 speed and a stout tranny at that. There are heavily modified 12V Cummins that are having a hard time breaking one, Chevy also used the NV4500. If you can find one you could also use a NV5600 and have a 6 speed with od. And as bigperm2 stated you can use your FE bell and buy a much cheaper adapter to use these trannys.
Old 03-07-2012, 09:28 AM
Creamsiclejohnson
people make adaptors for one that arent actualy ment for a FE block im trying to find one that uses a adaptor and where to get it and what transmission to use
Old 03-07-2012, 09:31 AM
Creamsiclejohnson
where can i buy the adaptor andwhat else would i need other than the adaptor like lickages and clutch parts and would i need to get a new shaft to go to the motor?
Old 03-07-2012, 09:45 AM
Creamsiclejohnson
what i realy need is someone to just give me a transmission and then a list of everything i would need with it to make it work and tell me where i can get it
Old 03-07-2012, 10:07 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Old 03-07-2012, 12:12 PM
crazy96863's Avatar
crazy96863
crazy96863 is offline
The Bronco Graveyard's got your back... NV4500
NV4500 Trans Kit (does not include transmission)
Here is a write-up on a similar swap I found on this site...
Installing the NV4500 Overdrive Transmission .: Articles
I read elsewhere that the FE engine acts a little quirky when you bolt an overdrive to it while being perfectly content with spinning at 3000 rpms all day. You can find more info if you do a general internet search for '390 NV4500' or something to that extent.
If its mileage your looking for you might get more bang for the buck with other mods such as intake, exhaust, fan, ignition, weight, gearing, etc... A combination of a few of these might get you a few extra miles with other performance perks a tranny swap may not offer. If engine wear is the concern I believe it was built for this and has lasted 40 years doing so. She is a tough old girl.
I am not trying to talk you out of it; in fact I might look farther into it down the road but at this point she has got plenty of other things to keep me busy.
Old 03-07-2012, 10:49 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Quicktime makes an FE bell housing for a TKO-500. Around $500 for just the bell housing and then add another $2100 for the TKO.
Old 03-07-2012, 11:07 PM
dkf's Avatar
dkf
dkf is offline
Looks like this place has some options for an FE to ZF5.
High Impact - ZF 5spd
Quick Reply: 5 speed on a 390 FE in my 73 F250
