Need opinon on Lift..???? - Ford Truck Enthusiasts Forums
Old 03-06-2012, 07:42 PM
DaXman's Avatar
DaXman DaXman is offline
DaXman is starting off with a positive reputation.
Zup guys,,,i'm kinda new to the Diesel world (had a 2004 F350 6.0 way back)
Now i have a 2003 Excursion 2x4. All i've done to it is install a 2008 front end, now i want to have the lifted look.
I wanted to go 6" lift, with some wheels, but i hear that the 2x4 models need a 8-9" lift to look high enough.
Please give me some input,opinions,recomendations....Thanks.
Old 03-06-2012, 09:05 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
high enough for what?
Old 03-06-2012, 09:33 PM
Swagtastic Swagtastic is offline
Swagtastic is starting off with a positive reputation.
high enough to clear a midget without touching
Old 03-06-2012, 09:35 PM
Better make it 30" with at least 38's to be safe, since midgets have to be under like 4'10". I wouldn't want the safety of my midget riding on anything less.
Old 03-06-2012, 11:03 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Gotcha covered...
I lifted my truck 5 years ago and have gone through this process enough to write a very detailed book on it.
You really only have two options when it comes to a 2wd lift: Procomp or Fabtech.
I went with the Procomp lift becuase they offered one type of lift with no variations. Fabtech on the other hand had a "basic" and "performance" 2wd lift kit which only made things confusing.
The procomp kit comes with a full leaf spring pack for the rear (NOT an add-a-leaf and block) as well as a full coil and the necessary hardware for the to get the front lifted.
You can buy the Procomp kit anywhere, but DO NOT buy it or anything from 4wheel online. They have the worst customer service, lost parts of my lift kit, and made many promises they never delivered on.
Things they don't tell/give you:
-You will need to purchase the pitman arm becuase they changed the amount of splines somewhere between early 2001 and late 2001. Since yours in an '03 you'll obviously need the later pitman arm.
-This isn't something you can in your driveway. I would highly recommend a shop doing the work as it not something you can do in your driveway.
-As far as tires, you CAN fit the recommended 35s on the factory 16 inch mags using size 315/75/16. In the 5 years I've been running the stock rims, I've never had a problem with the front end. (I.e. uneven tire wear, hubs falling apart, bad ball joints, etc)
-Yours being a diesel, the min and max you can go is 6 inches
-If you plan on regearing, you will need 4.10 gears to match the 35s to your 3.73s
Since installing my lift, my truck rides, drives, much better and is a night and day difference from stock.
Bottom line: It's one of the best things you can do for your truck
Old 03-07-2012, 01:31 AM
popups4rent popups4rent is offline
popups4rent is gaining momentum as a positive member of FTE.
What he said, except I did mine before the Fabtech kit came out and I run a 20" rim. I had mine done at 4 Wheel Parts, cannot recommend them.
You will also need to find a shop that can do a real alignment. The factory specs will chew up your tires.
My lift has 122K miles on it now.
Quote:
Originally Posted by Toreador_Diesel View Post
Gotcha covered...
Old 03-07-2012, 08:28 AM
DaXman's Avatar
Thanks toreador_diesel & popsuos4rent...........I will probably do that, except i will put some 20" wheels.
Old 03-07-2012, 08:34 AM
Forgot THE MOST important part in all this!!!
popups4rent is correct, factory specs will eat new tires in a short amount of time...
You need to find an alignment specialty shop becuase the alignment kit Procomp offers WILL NOT align your truck correctly. Alignment specialty shops have the proper cast and camber kit to make sure your alignment is dead on.
Old 03-07-2012, 08:36 AM
kdbd4 kdbd4 is offline
kdbd4 is starting off with a positive reputation.
I put a FabTech kit under my old excursion. Def have a professional do it, may cost a bit, but you'll avoid the headaches!
Old 12-19-2013, 02:07 AM
chopped50ford chopped50ford is offline
chopped50ford is starting off with a positive reputation.
i have a pro comp lift on mine and it rides very nice. 6" lift.
Old 12-20-2013, 10:31 AM
RobRoss's Avatar
RobRoss RobRoss is offline
RobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud of
Maybe this guy can help? It is a 4x2. 2004 Ford Excursion
Old 12-21-2013, 08:54 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Why on earth would it be something you can't do in your driveway?!
I've managed to do lots of lifts/4x4 conversions/axle swaps and what not in the driveway. What's so hard about this?
Old 12-22-2013, 12:21 AM
With the 2wd coil upfront and the drilling and dis-assemling that has to happen, it's always best to have a lift and a shop.
It's not as easy as it is with front leaf suspension trucks. I watched them do mine and even helped, it wasn't easy.
Old 12-22-2013, 12:29 AM
hav24wheel's Avatar
Can't be any harder than a TTB pickup like my old 94 F150. Pop out some rivets, drill some holes, bolt on some brackets, put in new springs, shocks, brake lines, and tires/wheels.
I know it's a bit of work, bit I've done lifts on TTB rigs in 6 hrs with floor jacks, jack stands, and basic hand tools. A torch, drill, and air tools make things easier of course.
lift kit recommendations for a 6/77 low boy F-250 4x4? Chris Popanz 1973 - 1979 F-100 & Larger F-Series Trucks 23 11-29-2015 12:14 PM
Need some lifted superduty measurements please. 3/4ton4X4 1999 to 2016 Super Duty 3 08-31-2014 01:55 AM
Lift Advice 4" or 6" ClayX Excursion - King of SUVs 24 01-03-2014 02:12 PM
Lift need for my truck to clear 35s Ken904 1987 - 1996 F150 & Larger F-Series Trucks 0 12-26-2013 12:37 AM
Opinions on lift kits for 86 f250 4x4 Eallend7 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 11-19-2012 06:45 AM
Tags
124, 2x4, coil, excursion, fabtech, ford, fts, lift, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
