Check coolant additive
You're supposed to perform a test on the coolant which will show if it's at the proper mix. That's a really generic description but it's the best I can give. I know for sure that Lewis Automotive Group in Dodge City KS will charge you for 20 minutes labor to perform the test regardless of whether or not you need any additional additive.
on
Here is the procedure from the manual.
If you do a search on here you will find lots of information.
It appears to me that some dealers are still not doing the test properly.
You need 2 kits to do the test 328-00001 and 328-00008.
I still see some posts that say "the dealer diped the strip into the degas bottle and it was good". For the 328-00008 test you need to remove coolant and mix 5ml with a solution in a vile (comes with the kit) and then test the mixture. This tests the corrosion inhibitor strength.
I also see posts that say"the nitrile level was normal". There is NO nitrile in specialty orange coolant, if ANY nitrile is present the coolant is BAD and needs to be changed.
The 328-00001 strips are ONLY used to test for % glycol and nitrile in the 6.7 coolant. Whatever the 3rd thing is on the strips it is not used.
If you take it in make sure they do it correctly, as far as I know the 328-00008 test is NEW for the 6.7 and was not prefromed on past super duty.
Thanks
Thanks
The message will pop up about every 13,000 to 15,000 miles.
It jst a reminder to check your antifreeze and make sure it's still good.
Darren gave you the details on how to check it. It is something you can wait till you get home, Not a immediate failure kind of message,
After checking it, you can reset the message int he command center by pressing and holding the OK button in the Coolant section. It will reset the internal clock for the next 15,000 miles.
The coolant is designed to last 105,000 miles under normal use and 60,000 miles under severe use. You can add the VC-12 additive to improve the corrision inhibitor ( 3rd test mentioned above) twice during the life of the coolant. It's about $14 a bottle. So I guess if you are on the average use schedule you would add the VC-12 around 35,000 and 70,000 miles and flush and refill at 105,000.
Just remember you have TWO coolant systems, They are independant of each other. So test both and add the VC-12 to both.
on
When I started my truck after work today guess what happened??
It said "Check coolant additive" TOO FUNNY
Here is what the kits look like FYI:
328-00001 This kit is used only to test glycol concentration and for the presence of any nitrile (not how much, any at all) The the Monybonite test you don't use.
328-00008 is ued to test the corrosion inhibitor strength.
Thanks!
Thanks!
There is enough to do 10 test. But since you have two systems, that means you have enough for 5 check coolant messages. If you drive 15,000 miles a year, that mean 5 years and I think if I remember correctly they have a 1 year expiration.
Chances are that unless you are a high mileage driver, the kit will expire before you use all of the test.
on
The /08 kits are good for just over 2 years. The only place I know of that you can get them is directly from Accustrip.
Thanks
Darren, I still can't rep you, and I really think Tom needs to post your info in the tech folder.
I did not know about the second test, I fall into the "early 6.7 truck" category.
Thanks for gettin me straight. I just had new coolant installed after the dealer flushed both systems. With our dual cooling systems and 4thermostats, I didn't want to mess with it....
I will be ready for the check message now thanks to you.
Much obliged.
Much obliged.
Much obliged.
Much obliged.
Does anyone know why this is after the factory fill flush (seems excessive)?
on
Much obliged.
Much obliged.
I am not going to mess with the coolant change myself either.
What mileage did you change the coolant at?
