Refurbishing 1965 F100 heater box - Ford Truck Enthusiasts Forums
Old 03-06-2012, 10:54 AM
Schuyles's Avatar
Schuyles Schuyles is offline
Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.
My heater core was leaking, so I bought a new one last summer. When I went to install it, I realized that all the foam and rubber seals had disintegrated. I just left it unhooked.
I finally got around to buying a kit ($18) to finish the job, and figured I'd post pictures and show how the job goes.
I took the box out of the truck yesterday. Here it is, along with the kit, before I get started.
Old 03-06-2012, 11:15 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
Where did you get the kit? Something I found out to restore a new look to the rubber isolater around the fan motor is to soak it in some stuff called evaporust. Makes it look like new.
Before evaporust
After evaporust
Old 03-06-2012, 11:22 AM
Schuyles's Avatar
Looks good, thanks for the tip!
I had read before that these kits for the early broncos work. The company is a few miles from me in Knoxville, so I went by and bought a kit. I do not know how much shipping is.
It seems like it's got everything we need.
It's at the bottom of this webpage: Classic fORD Bronco Replacement Parts, Gaskets and Seals
Old 03-06-2012, 02:07 PM
Buzz44's Avatar
Thanks I put them in my favorites.
Old 03-06-2012, 07:02 PM
William William is offline
William is gaining momentum as a positive member of FTE.
Heater Box Clip
There is a clip that retains the heater core. For the life of me I cannot see how this goes on. Anyone got an idea. I kept the clip and tied the core to the box with zip ties. I know that is not correct but really, I cannot figure out this clip.
Old 03-06-2012, 10:59 PM
OldHarley's Avatar
OldHarley OldHarley is offline
OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.
Quote:
Here is the exploded parts diagram. Hope this helps.
Old 03-06-2012, 11:53 PM
Boss9F100's Avatar
Boss9F100 Boss9F100 is offline
Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.
Proper location of clip:
Old 03-07-2012, 03:40 PM
Clip
Aha! He said slapping his forehead! Thank you so much for the parts diagram and the pictures. Oldharley and Boss9F100.
Old 03-11-2012, 09:49 PM
Schuyles's Avatar
I used Liquid Nails silicone to attach the foam to the flappers inside the box. It wasn't pretty, but hopefully will last for a while. I decided to use liquid nails because it said it could be used on foam. I didn't take the plate off the back of the box, so I just sort of got my hands in there where I could and finessed it through.
Old 03-11-2012, 09:51 PM
Schuyles's Avatar
As you can see, the pieces were all cut to fit our boxes perfectly. Even the holes lined up just about perfect on all pieces.
Old 03-11-2012, 09:54 PM
Schuyles's Avatar
The rest of these pictures just show how the pieces fit together. I had to trim down one of the large rectangular foam pieces, but other than that, they fit pretty good.
Old 03-11-2012, 09:58 PM
Schuyles's Avatar
I cleaned up the box a little bit, but didn't get into any sort of "restoration." I mainly just wanted the heater to be as functional as it could be.
This post was to show the kit for the early broncos in action. It seems like it does work for our standard heater box. Total cost $25.
Old 11-13-2014, 05:04 PM
Fancy65F100 Fancy65F100 is offline
Fancy65F100 is starting off with a positive reputation.
thanks for this post! very helpful as I restore the heater in my F100
Old 11-13-2014, 05:38 PM
Schuyles's Avatar
Quote:
I'm glad! Mine is still working great.
Old 08-13-2015, 12:25 PM
Jeff Ranger Jeff Ranger is offline
Jeff Ranger is starting off with a positive reputation.
i have to do this. I think i need a new core as mine smells when i run it and smokes the truck up
Eliminating the through-bed bolts Schuyles 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-06-2014 09:50 AM
Any idea what kind of radiator this is? Schuyles 1961 - 1966 F-100 & Larger F-Series Trucks 18 05-18-2012 06:37 PM
Should I replace a water pump? Schuyles 1961 - 1966 F-100 & Larger F-Series Trucks 20 03-31-2012 09:08 AM
1965 F100 240 heater hookup Schuyles 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-20-2012 02:33 PM
1965 F100 I-6 radiator (pictures) Schuyles 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-09-2012 09:29 AM
Tags
2008, 29, 60, 64, 65, case, core, diagram, diesel, engine, f100, ford, heater, manual, parts, transfer, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
