Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-06-2012, 07:30 AM
AlbyVA AlbyVA is offline
Garage is empty, add now
AlbyVA is starting off with a positive reputation.
2008 Ford F-250 6.4L Engine on CNG
Is there a kit to convert the 6.4L Diesel Engine to run on Compressed Natural Gas (CNG)?
My wallet cannot continue to afford +$4.00/gal Diesel.
  #2 (permalink)
Old 03-06-2012, 07:49 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
In a word, no
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 03-06-2012, 07:51 AM
Quote:
Originally Posted by fabmandelux View Post
In a word, no
BOOOOO.....
How about this followup question. What diesel engine does run on CNG that could be placed into a 2008 F-250? Maybe I could sell my 6.4L for something else that will run on CNG.
  #4 (permalink)
Old 03-06-2012, 08:02 AM
1935 Ford pickup
None. CNG engines are spark engines, not compression (diesel) engines. Why not make biodiesel?
__________________
  #5 (permalink)
Old 03-06-2012, 08:37 AM
I had my taste of 5% BioDiesel and I suspect it caused me more problems
than it was worth. A few years back, I had to have a major fuels system overhaul
because of 2 things which came together to cause my heart ache. That was running
biodiesel and not changing my fuel filter within a reasonable timeframe. The end result
was that all the junk ended up bypassing the filter and clogging the injectors. In the
end, it was an $8000 repair bill, although 50% of that was labor. But I needed all
new injectors, fuel rail, lines, and a good cleaning of the fuel tank. The mechanic
described the issue as jelly-like junk throughout my system. He couldn't put a finger
on it, but I figured the only logical possibility was biodiesel that I always used from a
local station. Lucky for me, the conclusion by the mechanic was "Bad Fuel" and I was able to get the insurance company to cover the whole repair costs.
Ever since then, I've have just decided to avoid biodiesel.
As for CNG and diesels, if they are spark and no compression, then how is it that you have T Boone Pickens hyping that America can get its 18-Wheeler fleet switched over to CNG when they all have Diesel engines?
  #6 (permalink)
Old 03-06-2012, 09:03 AM
1935 Ford pickup
I've been making and using B100 biodiesel for over 7 years now, and have never had any fuel problems at all. Untill I retired a year ago I ran the whole farm with it. I now sell my excess to a logging company and several farms, all with 0 problems. Your local station must of got a bad batch from it's supplier..............
__________________
  #7 (permalink)
Old 03-06-2012, 09:09 AM
....or could it be the 6.4L engine is just super sensitive to its fuel? I don't doubt
that biodiesel works, I've seen it work well when I used it. I'm just wondering if the
6.4L is just so advanced of an engine that anything short of pure ULSD diesel will
cause you issues.
  #8 (permalink)
Old 03-06-2012, 09:14 AM
1935 Ford pickup
That could very well be true. All my diesels are IDI, and I have no experience with the newer diesels. I do know that you do not use it in any diesel with a DPF...........
B100 is the best solvent in the world (I use it in my solvent tanks...) and will clean out a fuel system fast!
I'd have to check, but I think we have members here that do use it in their 6.4's...............
__________________
  #9 (permalink)
Old 04-22-2012, 12:53 AM
Aric Aric is offline
Aric is starting off with a positive reputation.
I run my vans on propane and have a lot of miles on them. 2 have 351 3 with 5.4l and 1 with a v10 and they work hard 5 days a week and some harder. I tried the diesel thing and gas I've even tried bio but I'm not one to put a lot of work into making something work nor do i have the space to make that much biodiesel to run them 5 days a week the v10 under stress cost me around .15 to .1875
  #10 (permalink)
Old 09-12-2012, 04:31 PM
Bseeton1 Bseeton1 is offline
Bseeton1 is starting off with a positive reputation.
In a word, no
your wrong
"CNG, compressed natural gas, is it the answer for the fuel crisis, we review a diesel/cng conversion."http://www.ewsews.com/cngprices.html
  #11 (permalink)
Old 09-18-2012, 10:46 AM
fraso fraso is offline
fraso is starting off with a positive reputation.
Diesel-CNG conversions are generally universal in that they are made for a range of engine displacements rather than for specific engines.
DIY CNG systems (like the one in Bseeton1's link) often use some sort of venturi (look for the 3/4" Type M copper pipe) upstream of the turbocharger to drawn natural gas into the engine. Many use the Impco Model J regulator but at least 1 uses (used?) the Model E. Since venturi vacuum increases with the square of air flow (3X the flow means 9X the vacuum), it is easy to overfuel (with meltdown caused by detonation) a diesel engine, which is why these systems usually have a manually-set throttle valve to limit CNG flow at maximum boost.
Commercial CNG systems use electronic fuel injection controlled by a fuel map in the ECU to meter natural gas according to measured parameters like boost pressure, RPM, throttle position, exhaust temperature, etc. This allows more diesel to be safely substituted with CNG and maximizing CNG use is the key to reducing fuel costs. Supplying the fuel post-turbo reduces the lag time and makes these systems much more responsive compared with pre-turbo supply.
Commercial aftermarket Diesel-CNG systems include:
The heavy duty truck use of natural gas promoted by T Boone Pickens is either using a diesel engine converted to natural gas or using a diesel-LNG dual fuel engine.
  #12 (permalink)
Old 09-18-2012, 10:59 AM
Great info
  #13 (permalink)
Old 09-21-2012, 08:46 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans is gaining momentum as a positive member of FTE.slowmans is gaining momentum as a positive member of FTE.
I use Bio in my 6.4, but im tuned and deleted.....I buy B-99 and mix accordingly. I am running B-20 right now and have been for months, not a single problem. I did the same thing in my 6.0 with no issues ( one gelled filter in the winter from running to high a concentration) But my truck runs perfect and I have changed the fuel filters once and they looked great!
I think the key is the fuel you buy, I buy my Biodiesel from a commercial maker ( newport Biodiesel) and its made great!
Tags
2008, 64, 64l, b100, biodiesel, cng, diesel, engines, f250, ford, forums, fseries, injection, running, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
