1978 Ford Cummins Crew Cab Conversion
that welder looks good has a 30-210 amp range
the only issue I see with it is it has a 150 amp 220v 30% duty cycle
would like to see duty cycle up around 50%
run it on the 220v and get the bottle don't use that flux-core it is junk
I emailed my rep at miller and he said good welder for home use just don't do any continuous welds longest weld you want to do is 60 seconds
http://www.millerwelds.com/pdf/spec_sheets/DC12-54.pdf
Well back at it this week. I have the Idea for the tank done I believe 26Lx34Wx14D I already have the Wema sending unit that I bought for the original tank plan so I will keep the same depth on the new Idea of 14". I am going to use a welded sump instead of the Hellman sump from the original idea. I am getting the AirDog Fuel Air Separation System 100 GPH (A4SPBD000) so I will run the male feed fitting behind or just below the crossmember to protect it and then just plug the female fitting from the FSS right to it.
This is the sending unit
Original sump idea
Original tank idea side view
Original sump idea
All we have ever called them were body jacks couldn't tell you where we got them I have a gantry hoist now which works much better.
Off to a good start your like me takin on this swap in my 71 crew I had to go buy a welder figured Nows the time instead of borrowing my friends once again I got the miller 252 and its great is that the I beam lift from harbor freight you used to put the cab back on? I keep getting side tracked with my build and hoping I finally get my motor mounts done this week been saying it for weeks now but keep getting other Things in the way of working on my truck I'll be watching for some progress good luck
#28
#29
I know this is old but thats 30% duty cycle with the welder turned all the way up to full amps. How often do you weld 3/8" plate? I have a 211 and have used it to weld toghether a full tube chasis. Its a great welder for the price. Very rarely will I do a full min long weld. Its usually weld a little fit a part move to a different spot weld a little etc.
