Will a 1987 6.9 diesel fit in a 1993 351 V-8 - Ford Truck Enthusiasts Forums
Old 03-05-2012, 11:29 PM
natejames natejames is offline
natejames is starting off with a positive reputation.
I am wondering if I can take a 6.9 Diesel out of a 1987 F-250 and put it in a 1993 F-350 that has a 351 gas V-8 has anyone done it and how did it go. Thank You!
Old 03-05-2012, 11:44 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
I don't see why it wouldn't fit. The transmission won't bolt up from the Windsor, so you'll need the diesel transmission. If you have the whole 87 it should be a pretty easy swap. Out of curiosity, why are you swapping out the 351?
Old 03-05-2012, 11:48 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is online now
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
You'll have alot of wiring issues since the 93 is computer controlled and the 87 isn't.
Old 03-05-2012, 11:58 PM
Or I would think anyways
Old 03-06-2012, 12:00 AM
I do have the whole 87 truck would that help the wiring issue
Old 03-06-2012, 12:02 AM
That would make things easier
As far as why I would prefer the diesel engine for towing
Old 03-06-2012, 12:04 AM
GNR22's Avatar
I'm not sure what wiring issues you would have. you should be able to get it to run in the truck no problem.
Midnite, what wiring issues were u thinking? Perhaps I'm overlooking something
Old 03-06-2012, 12:23 AM
I was thinking about the dash. With the 93 being the digitaldash and the 87 not. Dot know if the gauges would work or not. Then there's the computer for the 351/tranny.
I would almost pull the cluster and run a new set of aftermarket gauges but then gain I don't know how hat it would be to get the gauges to work
Old 03-06-2012, 12:24 AM
Darn auto correct on the iPhone, I hope that last post makes sense.... Or you can make sense out of it lol
Old 03-06-2012, 12:37 AM
GNR22's Avatar
I understand what you're saying...The temp and pressure gauges I'm not sure about. The speedo should still work. RPMs should work if it gets hooked back up. The fuel level gauge, I dont know I guess. A new tank and set up for diesel would need to be put in, so in theory it should work. If the speedo works, the Odometer should work too I think.
By the way, 6.9s are good pulling motors.
Old 03-06-2012, 12:46 AM
I forgot the speedo was of the rear diff not the tranny.
I had a 6.9l in my old 85 f250. That thing would pull what ever I put behind it as long a I didn't want to get here fast lol
Old 03-06-2012, 12:37 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
The 93 is not a digital dash ... Electronic yes, Digital no.
It can be done, Mechanically easy, Though it would be a wiring hack job!
The best way would be to find a 92-94 Diesel truck that you can get the wiring and dash out of.
-Enjoy
fh : )_~
Old 03-06-2012, 05:34 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Engine frame stands will have to be swapped and possably the crossmember to be modified for the diesel to fit.
For the electronics ,just pull off the sensors from the 351 and put them on the other engine so the guages will work using the orginal 351 harness. Just remove the wires that are for the EFI and leave the reset alone.
Old 03-06-2012, 09:35 PM
fordpower46 fordpower46 is offline
fordpower46 is starting off with a positive reputation.
Sounds like a lot of work for a minimal gain. A good running 351 can pull almost anything you can put behind it...the limits of the chassis and suspension arrive before the power ends. Remember the 6.9 is not turbocharged.
6.9 Diesel: 170hp, 338lb-ft
5.8 EFI V-8: 210hp, 317lb-ft
The only place you might gain a little is in fuel economy, but that is erased by the higher cost of diesel fuel.
4 wheel drive problems 1987 ford f250 6.9diesel 87diesel6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 05-18-2016 09:24 AM
6.9l diesel transmission options Midnite1987 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 04-17-2016 09:21 PM
1987 6.9 IDI High RPM tyler.dunn94 1987 - 1996 F150 & Larger F-Series Trucks 3 11-01-2015 07:03 AM
Possibly another new idi? tmill28 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 06-29-2014 10:03 PM
Can I put a chip in my truck? ConorsTowing Computer Chips & Tuners 3 07-04-2012 10:12 AM
Tags
1987, 1993, 351, 351w, 58, 69, 8ford, bronco, cleveland, diesel, f250, f350, ford, put, putting, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
