Will a 1987 6.9 diesel fit in a 1993 351 V-8 - Page 2 - Ford Truck Enthusiasts Forums
Old 03-06-2012, 10:56 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Quote:
Originally Posted by fordpower46 View Post
Sounds like a lot of work for a minimal gain. A good running 351 can pull almost anything you can put behind it...the limits of the chassis and suspension arrive before the power ends. Remember the 6.9 is not turbocharged.
6.9 Diesel: 170hp, 338lb-ft
5.8 EFI V-8: 210hp, 317lb-ft
The only place you might gain a little is in fuel economy, but that is erased by the higher cost of diesel fuel.
I guess I didn't know the exact numbers that a 6.9 put out for power. But I bet a good exhaust and set of headers for a 5.8 put you're above the torque specs for a stock 6.9
Old 03-10-2012, 05:14 AM
burnout400m burnout400m is offline
burnout400m is starting off with a positive reputation.
I would say if the 351 isn't doing it for you then just search for another truck with a diesel already in it. Or the 460 if you don't care about fuel economy. The right gears make a big difference too.
Old 05-18-2014, 09:43 AM
bluethundersowner bluethundersowner is offline
bluethundersowner is starting off with a positive reputation.
Im trying to do the same thing right now but using a 85 6.9 and cab swapped a 89 5.8 and cannot find good wiring diagrams to figure it out. Could you help me out?
Possibly another new idi? tmill28 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 06-29-2014 10:03 PM
Can I put a chip in my truck? ConorsTowing Computer Chips & Tuners 3 07-04-2012 10:12 AM
Wiring harness 6.9 diesel ahha-retired! Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-20-2011 09:22 AM
Questions about two (86 & 87 F250 6.9L Diesels) Resendiz 1987 - 1996 F150 & Larger F-Series Trucks 7 01-30-2011 11:55 PM
1987 6.9 diesel problems please help DirtyIntentionsOffro Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 06-12-2010 12:35 AM
Tags
1987, 1993, 351, 351w, 58, 69, 8ford, bronco, cleveland, diesel, f250, f350, ford, put, putting, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
