I need your Help - Blend Door Actuator Issue - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-17-2014, 06:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Old 03-05-2012, 09:51 PM
paulcalif paulcalif is offline
paulcalif is starting off with a positive reputation.
99 F250 Superduty Crewcab, V10. Heater stuck on hot. Fan works fine and I can direct the hot air to the correct areas (floor, vents, defrost). I've been through the forums and was pretty sure I needed a new Blend Door Actuator. Pulled the actuator off and put a 1/4" socket extension into the top of the blend door. It moves freely. While the blend door actuator was out, I moved the temperature control rheostat, but the actuator didn't move. Pulled the **** on the rheostat temp controller and it was fine. I'd like to test the rheostat but I don’t know how to pull it out. I guess I could jury rig a couple of connectors, or put pins through the wires, but if it’s easy to remove, I would rather do that. I purchased a used Actuator on ebay and it doesn’t work either (connectors were GREEN with corrosion, cleaning didn’t help). At the actuator there are five wires. I get 12V. across two of them, but don’t know what else I am looking for. Could really use some help trying to figure this out. The dealer wants a lot of money for a new actuator, hench the used ebay part. I've messaged the "partsguyed" and I'm waiting for a reply. Forgot to mention, I check the fuse that protects the blend door actuator, it's fine. I also check ALL of the fuses inside the cab.
Thanks in advance, Paul
Old 03-05-2012, 09:57 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Is your vaccum pump working? Thats the most likely cause of not being able to redirect air in our trucks!
Old 03-05-2012, 11:08 PM
Thanks for the quick reply
I CAN redirect the air, but the air is stuck on hot. It's my understanding that the blend door controls whether heat enters the cab or not. I'm also pretty sure that vacuum controls the valve(s) that directs the air. The blend door actuator is not working. Am I wrong?
Thanks again for the reply
Old 03-05-2012, 11:46 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
You're on the right track. I've attached two diagrams. The wiring diagrams will show which wires are the variable resistor, power and ground going to the blend door actuator. The second one is the plug diagram.
This should allow you to test the variable resistor from the blend door plug, and make sure it's getting power and ground properly.
Old 03-06-2012, 10:50 AM
BIG HELP!! THANKS!!
Exactly what I needed.
Thanks!!
I will post back with my results.
Paul
Old 03-06-2012, 11:49 AM
That was fun and telling, here are the results.
Tested from wiper to one side of rheostat - Nice even resistance change from 17 ohm to 5000 ohm.
Tested from wiper to other side of rheostat - 5000 ohm to 17 ohm.
Tested from Voltage in Run (hot) to Ground - 12V with key on.
This tells me the rheostat is functioning properly and that I am getting the required voltage.
Since the actuator isn't moving - it is faulty, both my original AND the one I purchased on ebay.
Now - I think I can test the actuator by connecting 12V to "Voltage in Run" Ground to Ground and connecting a jumper across wiper to either side of the connection that would go to the other side of the rheostat, but just to be sure, I am going to dig up a rheostat and connect it properly.
Will post back.
Bottom line is, I need WORKING blend door actuator.
Paul
Old 03-06-2012, 12:57 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
Quote:
V10 dont have vacume pumps only diesels do..
Old 03-06-2012, 09:00 PM
Fixed - Thanks!!
It was the Actuator all along.
I found an after market one available from O'Reilly's. Once I had the part number, I was also able to find it on Amazon for less. But since I wanted it today, I paid the extra $8. Total came to about $39. Cool! I paid more than that for the used one that doesn't work on eBay!!
Anyway, moral of the story is, test the wiring if you know how. If not, send me a private message and I will tell you how.
Symptoms are - Fans works fine, you can direct the air to the various vents, but the temp control has no effect. It can be stuck on Hot, or Cold, or somewhere in between. More than likely, if you experience the above symptoms, you have a bad Blend Door Actuator (a small motor assembly used to turn a door open or closed, which isolates your heater core). You may also have a broken Blend Door or shaft going to the blend door. Fixing a Broken Blend Door is a big job. I found a company that claims to have a easier fix here - Heater Treater: Blend Door Fix, Heat and A/C Replacement Parts
Hope this helps someone one day.
Thanks for the help
Old 03-06-2012, 10:29 PM
RedBoat's Avatar
Rather Be Floatin
Quote:
Oops, no siggy so I just assumed it was a diesel! Does'nt everyone drive a diesel?
Glad you got it fixed Paul!!
Old 03-06-2012, 10:50 PM
Only the ones that can afford it
Old 11-18-2012, 12:29 AM
kg4ysy kg4ysy is offline
kg4ysy is starting off with a positive reputation.
I just wanted to say thanks. This post allowed me to fix the problem in my truck. A $50 part was much better than losing my truck for a day at Ford and at least a couple hundred in cost.
The part I ordered doesn't fit 100%, but the heat works again. I can't complain.
Old 08-29-2014, 01:59 PM
AAubinoe AAubinoe is offline
AAubinoe is starting off with a positive reputation.
Great info here. I am having the same issue. I even took the door control unit apart and all the gears were good. So if it is fried, its the motor.
Two questions:
If the manual AC and 'electric' AC use different pins for different wires, why is there only one unit sold at my parts store?
Is there a fuse for this unit? Could not find one.
Thanks
Would you buy OEM ford for this? Not 100% sure mine is OEM, but it has the OEM part number on the sticker and says 'MAN' which I assume says manual.
http://shop.advanceautoparts.com/p/d...archTerm=blend
I can get this in 2 days from Amazon, still $35 less then the dealer wants for it.
Amazon.com: Genuine Ford 1L2Z-19E616-CA A/C Motor Assembly: Automotive Amazon.com: Genuine Ford 1L2Z-19E616-CA A/C Motor Assembly: Automotive
I still have not tested if the plug is even getting 12 volts, but from the looks of things I dont see how it could be anything else BUT an internal issue in the actuator motor itself. Going to go test it with 12 volt first.
Old 01-22-2015, 02:32 PM
goodwinpro goodwinpro is offline
goodwinpro is starting off with a positive reputation.
I have the same problem (only blows HOT air) EXCEPT: I know my blend-door and motor are working.
Blend door is fine, brand new control rheostat, brand new actuator motor. But when I plugged-in the motor and turned on the key, it immediately went to full-on HOT and won't move from there.
Where do I start looking for the solution? It thinks the control **** is set all the way to hot, but I bought a new rheostat and that didn't make a difference.
Any suggestions?
Blend door and switch changed still No Heat Paul_inCT 1999 to 2016 Super Duty 5 11-16-2016 04:45 PM
Deadhorse....blend door? David Flint Cooling, Heating, Ventilation & A/C 5 06-21-2015 06:44 PM
Blend Door Actuator GloveGuy Cooling, Heating, Ventilation & A/C 2 08-11-2013 09:43 AM
EATC / Blend Door Actuator Problem b2trausch Explorer, Sport Trac, Mountaineer & Aviator 0 05-28-2007 02:27 PM
Fuse for blend door actuator coastie-ford 1997 - 2003 F150 4 01-31-2007 07:44 PM
Tags
2009, 30, actuator, blend, blend door, broken, door, duratec, f250, ford, heater, hot, motor, stuck, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
