1950 Ford F1 Axle and Gear choice
First off, the bolt pattern is 5 on 5 1/2", not 5 on 5. That is what the stock front axle is btw. As far as gears with a flathead, I would defer to those with experience with the engine (not me).
Mine came with one already in, but I had to pull it and re-mount the perches as the pinion angle was around 12 degrees. You will also need the driveshaft yoke to fit the 9" to get it grafted to your driveshaft.
BalootheBronco
15
02-22-2018 08:26 PM
tardster
12-31-2010 09:25 AM
motorhead_83
04-24-2003 02:11 AM
