1950 Ford F1 Axle and Gear choice - Page 2 - Ford Truck Enthusiasts Forums
Old 06-30-2014, 11:53 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
First off, the bolt pattern is 5 on 5 1/2", not 5 on 5. That is what the stock front axle is btw. As far as gears with a flathead, I would defer to those with experience with the engine (not me).
Mine came with one already in, but I had to pull it and re-mount the perches as the pinion angle was around 12 degrees. You will also need the driveshaft yoke to fit the 9" to get it grafted to your driveshaft.
Axle Compatability Bubba Jones 1978 - 1996 Big Bronco 18 02-15-2016 12:04 AM
3.55 Elect VS 3.31 Non-Limited Slip noserider 2015+ F150 56 02-09-2016 08:07 AM
front gear ratio neonjohn 1987 - 1996 F150 & Larger F-Series Trucks 4 05-04-2015 01:04 PM
Gear Ratio? Rusty830 1997 - 2003 F150 9 03-20-2015 08:10 AM
Gear Ratio Help Gear619 1987 - 1996 F150 & Larger F-Series Trucks 3 07-14-2014 05:35 PM
Tags
1950, 49, axle, end, f1, ford, gear, hole, inch, length, numbers, pattern, pickup, ratio, rear, swap, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
