Well I fixed the ebpv oil leak but now my hpop is leaking. I verified it for sure, I can see oil at the plug on rear of it. Would I be smart to install the T500, I plan on bigger injectors and chip in future. Any advice is appriciated. Thanks Chad!
Ok well the hpop has 275,000 on as far as I know. How much is the t500 going for now? I will look into a super duty hpop tomorow, I have read they are an improvement over stock.
Chad, simple fix. Remove the 11/16" plug and replace the O ring with a Viton #6 O ring.
