Put power steering fluid in the coolant container
Out of my stupidity, to make a long story short I put power steering fluid in my coolant container. I only drove it maybe five times after that. Today while going down the road the top to the coolant blew off and everything inside of it spilled out. I filled it with water to get through the day. I also bought a bottle of this stuff for people that do stupid stuff like me that cleans it out. What problems could I run into with this being done and should I drain the radiator as well?
to do it yourself will require at least all weekend I'd say. Drain it..then distilled water to flush, then the cleaner, then some more flushing then the correct mix.
In the mean time you have to cirulate it and that would mean driving it or sitting there on high idle.
That is not the correct procedure i am sure but gives you an idea that it is lengthy based upon what has happened.
I feel you wanting to DIY it. I'd feel the same way. However, if you're not familar with the cavitation problem these trucks can have and what it does to the motor you should probably search the forum for info. Bottom line, if you don't get it done completely and correctly you run the risk of a very expensive repair in a few months. Just FWIW.
CousinCarl
15
07-23-2018 09:43 AM
choate
08-18-2014 04:31 AM
Rotterdam24
06-19-2012 09:59 PM
awq134
2009 - 2014 F150
13
04-09-2012 05:55 AM
