power booster
Old 03-05-2012, 12:20 PM
christurney77's Avatar
christurney77
christurney77 is offline
power booster
Is this the power booster that I should purchase?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
If not, which one would you guys recommend?
Old 03-05-2012, 04:16 PM
newold46's Avatar
newold46
newold46 is offline
That looks like a nice setup. I've been looking at those also, but for now I'm sticking with the juice box and drums.
Old 03-05-2012, 06:54 PM
marine1200's Avatar
marine1200
marine1200 is offline
Whats the difference between this one? I know its a 3 bolt setup that we need to get. Im looking at getting the setup as well.
Power brakes FORD TRUCK, 1947,48,49,50,51,1952, all other 3 bolt master cyl aps | eBay
Old 03-05-2012, 08:19 PM
newold46's Avatar
newold46
newold46 is offline
It looks like the same type of setup with the first one coming with a brake pedal and the second one you reuse your own. Looking at the pictures, I (personally) can't figure out how you mount the thing to the frame. The second one looks easy enough to mount, but the adapter looks kinda flimsy. (once again, to me)
The master cylinders look to be the same model as well as the booster, so I would guess and say the are essentially the same, just the mounting method looks different. (to me)
Ok, I went and looked again and the first one posted is for the cars, the second for the truck. No wonder I couldn't figure it out...
Old 03-05-2012, 09:21 PM
christurney77
Maybe this model??? I guess maybe some kind of adapter would have to be made. (maybe one of our 48'-56' peeps could tell us)
1948 52 FORD TRUCK BRAKE PEDAL BOOSTER MASTER DISC DISC | eBay
Old 03-12-2012, 12:08 PM
christurney77
I guess this is the booster I'm going to purchase. I'll let you guys know how it goes.
Old 08-07-2012, 02:01 PM
marine1200's Avatar
marine1200
Did you ever buy the booster?
Old 08-07-2012, 02:37 PM
christurney77
Yes.... I purchased from Ebay. My only complaint is the company didn't supply installation instructions. They said they didn't want to be liable in case of an accident? Anyway, I need to get back on updating my build thread. Here are some pics.
Old 08-07-2012, 02:41 PM
christurney77
I didn't use the frame mounting bracket that was supplied. I instead modified my transmission crossmember to mount everything to. I was able to use the far right hole from the old brake setup. In welded some angle iron together and made a frame under the booster to strengthen the crossmember back up.
Old 08-07-2012, 02:43 PM
christurney77
I need to order my lines and finish plumbing the brakes. But right now I'm finishing putting new pins in the rear springs and fixing the steering box...... Then back to the brakes. (hopefully around the end of the month)
Old 08-07-2012, 05:21 PM
marine1200's Avatar
marine1200
Looking great man...which kit did you buy from ebay? I think you said you were running disk/drums?
Old 08-07-2012, 05:22 PM
marine1200's Avatar
marine1200
I see the brake pedal so you must have bought the one you first mentioned? Not the link for the truck setup without the pedal?
Old 08-07-2012, 06:24 PM
christurney77
daviselliott13
02-13-2010 09:18 AM
53OlderThanMe
31
04-21-2008 07:24 PM
WIF250
05-01-2007 11:41 AM
tywhitaker
15
11-10-2004 03:21 PM
634x4nut
11-23-2003 09:59 PM
Quick Reply: power booster
