power booster
power booster
Is this the power booster that I should purchase?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
If not, which one would you guys recommend?
Whats the difference between this one? I know its a 3 bolt setup that we need to get. Im looking at getting the setup as well.
Power brakes FORD TRUCK, 1947,48,49,50,51,1952, all other 3 bolt master cyl aps | eBay
It looks like the same type of setup with the first one coming with a brake pedal and the second one you reuse your own. Looking at the pictures, I (personally) can't figure out how you mount the thing to the frame. The second one looks easy enough to mount, but the adapter looks kinda flimsy. (once again, to me)
The master cylinders look to be the same model as well as the booster, so I would guess and say the are essentially the same, just the mounting method looks different. (to me)
Ok, I went and looked again and the first one posted is for the cars, the second for the truck. No wonder I couldn't figure it out...
Maybe this model??? I guess maybe some kind of adapter would have to be made. (maybe one of our 48'-56' peeps could tell us)
1948 52 FORD TRUCK BRAKE PEDAL BOOSTER MASTER DISC DISC | eBay
I guess this is the booster I'm going to purchase. I'll let you guys know how it goes.
I didn't use the frame mounting bracket that was supplied. I instead modified my transmission crossmember to mount everything to. I was able to use the far right hole from the old brake setup. In welded some angle iron together and made a frame under the booster to strengthen the crossmember back up.
daviselliott13
02-13-2010 09:18 AM
53OlderThanMe
31
04-21-2008 07:24 PM
WIF250
05-01-2007 11:41 AM
tywhitaker
15
11-10-2004 03:21 PM
