power booster - Ford Truck Enthusiasts Forums
power booster
Old 03-05-2012, 01:20 PM
christurney77's Avatar
christurney77 christurney77 is offline
christurney77 has a good reputation on FTE.christurney77 has a good reputation on FTE.christurney77 has a good reputation on FTE.
power booster
Is this the power booster that I should purchase?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
If not, which one would you guys recommend?
Old 03-05-2012, 05:16 PM
newold46's Avatar
newold46 newold46 is offline
newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.
That looks like a nice setup. I've been looking at those also, but for now I'm sticking with the juice box and drums.
Old 03-05-2012, 07:54 PM
marine1200's Avatar
marine1200 marine1200 is offline
marine1200 is gaining momentum as a positive member of FTE.
Whats the difference between this one? I know its a 3 bolt setup that we need to get. Im looking at getting the setup as well.
Power brakes FORD TRUCK, 1947,48,49,50,51,1952, all other 3 bolt master cyl aps | eBay
Old 03-05-2012, 09:19 PM
newold46's Avatar
It looks like the same type of setup with the first one coming with a brake pedal and the second one you reuse your own. Looking at the pictures, I (personally) can't figure out how you mount the thing to the frame. The second one looks easy enough to mount, but the adapter looks kinda flimsy. (once again, to me)
The master cylinders look to be the same model as well as the booster, so I would guess and say the are essentially the same, just the mounting method looks different. (to me)
Ok, I went and looked again and the first one posted is for the cars, the second for the truck. No wonder I couldn't figure it out...
Old 03-05-2012, 10:21 PM
Maybe this model??? I guess maybe some kind of adapter would have to be made. (maybe one of our 48'-56' peeps could tell us)
1948 52 FORD TRUCK BRAKE PEDAL BOOSTER MASTER DISC DISC | eBay
Old 03-12-2012, 01:08 PM
I guess this is the booster I'm going to purchase. I'll let you guys know how it goes.
Old 08-07-2012, 03:01 PM
marine1200's Avatar
Did you ever buy the booster?
Old 08-07-2012, 03:37 PM
Yes.... I purchased from Ebay. My only complaint is the company didn't supply installation instructions. They said they didn't want to be liable in case of an accident? Anyway, I need to get back on updating my build thread. Here are some pics.
Old 08-07-2012, 03:41 PM
I didn't use the frame mounting bracket that was supplied. I instead modified my transmission crossmember to mount everything to. I was able to use the far right hole from the old brake setup. In welded some angle iron together and made a frame under the booster to strengthen the crossmember back up.
Old 08-07-2012, 03:43 PM
I need to order my lines and finish plumbing the brakes. But right now I'm finishing putting new pins in the rear springs and fixing the steering box...... Then back to the brakes. (hopefully around the end of the month)
Old 08-07-2012, 06:21 PM
marine1200's Avatar
Looking great man...which kit did you buy from ebay? I think you said you were running disk/drums?
Old 08-07-2012, 06:22 PM
marine1200's Avatar
I see the brake pedal so you must have bought the one you first mentioned? Not the link for the truck setup without the pedal?
Old 08-07-2012, 07:24 PM
1986 F150 Power Brake Booster Lightning23 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 12-10-2016 04:27 PM
Booster brackets Mason R 1967 - 1972 F-100 & Larger F-Series Trucks 7 10-20-2016 12:03 PM
69 F100, Compatible brake booster for big block LCarter69 1967 - 1972 F-100 & Larger F-Series Trucks 5 08-05-2016 08:38 PM
Has anyone tried this MasterCylinder\Booster? Mikulh 1967 - 1972 F-100 & Larger F-Series Trucks 13 05-06-2016 12:14 PM
Has anyone bought one of these? dsrtjeeper 1961 - 1966 F-100 & Larger F-Series Trucks 18 11-04-2013 02:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
