Rebuilding the '41....again
Here's a link you might enjoy then.
Rose and Iris
The trucks name is 'Rose'. This website chronicles the original build from all original to the first iteration of Flathead with the C-4, and now the new build with the Small Block Ford. Hope you enjoy.
Rose and Iris
on
I hated pulling the Flat head out too.....but it went to an excellent home. I sold it to a fellow who is a flathead fanatic and actuallt had a hand in the original build on this truck. It's destined for a 1940 Coupe he has so it will stay on the road. In front of that C-4 automatic. you really had to DRIVE this truck before..... low vacuum, low RPM etc etc.
I'm putting a 302 HO motor in it:
I removed the original cross member and am installing a Fatman Fabrictions cross member and hub to hub stage 3 with power rack and pinion etc:
Got the corner turned, now all I need do is fabricate the motor mounts and can re assemble.
billslk32
11-21-2012 01:19 AM
cbwarrior
11-02-2002 07:13 AM
