1988 F super duty runs with a skip
03-05-2012, 09:44 AM
on
I have a 7.5 gas motor that has been rebuilt. Everything went together well. We have 2 new fuel pumps and the pump on the frame rail is also new with a new filter. New map sensor, new dist., plugs, wires, cap, rotor, coolant temp sensor, -almost evry sensor has been replaced - and new injectors. We just set the timing again and double checked that the plug wires and injector harness were properly hooked up. On start up it runs a little rough, but once it warms up, it only gets worse - it has a skip and seems to be dumping excess fuel into the cylinders. Any ideas??? Thanks
03-05-2012, 10:38 AM
Moved to the 1987 - 1996 F150 & Larger F-Series Trucks forum.
03-05-2012, 11:55 PM
Have you checked the injectors? Either replaced them or had them tested?
03-06-2012, 03:58 AM
on
yes- they were replaced with new ones
03-06-2012, 06:51 AM
I don't see anything about the fuel pressure regulator.
Is there fuel in the vacuum hose?
What pressures do you have at idle and with open throttle?
03-06-2012, 07:13 AM
on
new fuel pressure regulator - no fuel in vaccuum line.
35 lbs at idle - hard to get full throttle because it runs so poorly, but fuel pressure jumps up when given added throttle
03-06-2012, 09:53 AM
I wonder if your coil is getting messed up when it gets warm, I've had that happen on an old Honda.
03-06-2012, 10:01 AM
on
I thought of that but the coil is new as well - not that it couldn't be bad- you know how some of these parts are
Bodybag
1978 - 1996 Big Bronco
01-07-2019 04:08 PM
yellowzx01
15
03-11-2010 11:29 AM
77Explorer
02-15-2009 06:08 PM
mattoney
Bronco II
64
08-10-2007 05:14 PM
thomadm
01-06-2007 05:06 PM
